Home > General (L494) > WATER IN BATTERY TRAY IN BOOT
maci234
anyone had this before battery tray had a fair bit of water in it where would this be coming from
Post #588470 Fri Oct 11 2019 9:25pm
Tiger
Russia
Open the trunk trim on the left and right.
There are pipes draining water from the sunroof of the car.
Apparently one of these tubes clogged and jumped out of the plastic corner which is installed in the body.After removing the skin of the trunk on the traces of water you will see.
Post #590107 Fri Nov 08 2019 3:13pm
maci234
what do you mean where are pipes located
Post #590562 Mon Nov 18 2019 5:40pm
maci234
can you tell me more about this
Post #590623 Tue Nov 19 2019 5:20pm
Tiger
Russia
Check behind the rear doorways for these tubes. Left and right in the Luggage compartment.
This is a water removal tube from the roof of the car
Post #590637 Tue Nov 19 2019 9:12pm
maci234
do i have to remove carpets to see them pipes or where are these exactly thanks
Post #590651 Tue Nov 19 2019 11:01pm
maci234
can you tell me exactly where these are right and left and do i have to remove carpets
Post #590676 Wed Nov 20 2019 1:29pm
maci234
GOT THEM BUT WERE FINE THANK YOU
Post #590749 Thu Nov 21 2019 4:38pm
Tiger
Russia
Highlighted in red these tubes.
On the left, the tube is disconnected from the corner that is inserted into the body of the car.
Did you find traces of water?
Post #590981 Mon Nov 25 2019 5:04pm
maci234
checked them but perfect all in tact and clear not blocked
Post #590982 Mon Nov 25 2019 5:07pm
Tiger
Russia
And in the compartment under the battery, under the pneumatic compressor there is water?
Post #590983 Mon Nov 25 2019 5:12pm
maci234
yes but where is it coming from ,all sunroof drains are fine and checked , battery tray itself can get full of water , new boot seal ,sealed behind number plate
Post #590986 Mon Nov 25 2019 5:28pm
maci234
any other ideas where this might be coming from
Post #591131 Thu Nov 28 2019 4:21pm
maci234
any idea where else
Post #592354 Wed Dec 25 2019 9:33pm
Site Copyright © 2005-2020 Futuranet Ltd & Martin Lewis
