Home > General > Its back in the garage again..... |
Stand Easy Member Since: 10 Aug 2016 Location: Manchester Posts: 123 |
Bit long winded but bear with me...
Wed Nov 06 2019 9:14pm |
It's not had a regrind I'm told, they showed me the old crank and told me they had hoped to have it reground but it was too far gone, where they've sourced the crank from I don't know. I don't yet know what has caused the oil leak so can't question their workmanship yet and as I say the other jobs have all been done without issue or repeat. I'll await their response to what this fault is and go from there. It's a lovely car and I love being in it but it's getting a bit of "what next?" |
Wed Nov 06 2019 9:44pm |
Stevepd Member Since: 22 May 2017 Location: Wiltshire Posts: 1240 |
Hard to say as it’s your decision. It’s a question of do you trust them and the car? Just as in any car purchase the honeymoon period ends and you get to know what you’ve got. If it were me I’d be looking for a refund and start looking again, there are plenty out there and even buy one from a Forum member if you can hold out. Ultimately it’s down to you...... 2006 2.7 TDV6 HSE in Cairns Blue. |
Thu Nov 07 2019 9:49am |
Brit Plumber Member Since: 05 Jan 2018 Location: Sleaford, Lincolnshire Posts: 1847 |
I’m no expert but if you have an oil leak I’d be thinking it’s a crank shaft oil seal gone or crank moving in the seal, or the oil pump has fractured (is the pump on the front?)
Thu Nov 07 2019 11:12am |
LandPhil Member Since: 10 Feb 2015 Location: Suffolk Posts: 227 |
One thing you can be sure of is that you have not had a new crank fitted, you can’t get one, so you have an unknown secondhand crank.
Thu Nov 07 2019 12:41pm |
ilard Member Since: 20 Aug 2010 Location: London Posts: 972 |
I think fair play to the garage, they are getting on with it and not complaining or fighting you.
Thu Nov 07 2019 11:04pm |
Hog Member Since: 03 Dec 2015 Location: Wassenaar Posts: 254 |
I agree. usually if you got a crank failure, the egine should be swapped. Only changing the crankshaf is not a wise option. You take the risk of a catastrofic engine failure (and according to murphey's law after your warranty has expired). RRS 3.0 SDV6 HSE Lux RRS 3.0 TDV6 gone LR 3 HSE V8 gone DiscoveryII V8 Gone Discovery 1 V8 Gone Mustang Shelby Alfa Guilia (classic) |
Sat Nov 09 2019 1:48pm |
Eaters Member Since: 11 Apr 2016 Location: East Sussex Posts: 1532 |
As others have already said, it is ultimately down to you. However these cars have plenty of capacity to throw expensive problems at you once your an established owner so buying one with ongoing problems when you have the option(?) to back out of the deal then back out sounds the better way out to me. There are plenty of other RRSs out there to choose from so I'd be inclined to cut your losses now before they go stratospheric. Of course if you know something we don't about its history, then that might alter your decision.
Sat Nov 09 2019 5:35pm |
Thanks for your comments, all valid of course. I take the point that a new crank, or replacement crank is possibly not the best solution however from the garages perspective they're going to do the cheapest option to get it back on the road. Albeit it's been back 5 times in 4 months I have had all issues resolved and some of these have been done at a cost well above the warranty limit or outside the warranty agreement completely, at no cost to me, except for inconvenience.
Mon Nov 11 2019 1:38pm |
knwatkins Member Since: 09 Sep 2018 Location: Poole, Dorset Posts: 1138 |
I think the only thing we can do it wish you the very best of luck with it.
Mon Nov 11 2019 2:27pm |
Thanks, I picked the vehicle back up last Friday, I was shown an oil seal that basically slides over the front of the crank, this is what was leaking the oil, somehow it had come lose. Whilst in there they replaced the timing belt so I guess that's one less thing to be concerned with. I have 2 months left on the sellers warranty so hopefully I'll not need to call on it. |
Mon Nov 11 2019 4:05pm |
