Home > Technical > 2007 RRS 3.6 key fobs not working
dmorris66
Key fob stopped working to lock and unlock car - assumed batteries dead as don't use the car a lot and it is an 07 - changed battery on pcb but the fob still does not work. Checked voltage on other fob and battery same voltage as new battery but that fob doesn't work either - voltage dips when press a button - any ideas?
This is without installing the pcb and key into new fobs I ahve bought but can't see that would stop fob function working.
Cheers,
Dean
Post #589839 Mon Nov 04 2019 2:00pm
Boxers
United Kingdom 2007 Range Rover Sport TDV8 HSE Zermatt Silver
Haven't had mine long same model as yours exactly but the handbook says that the battery charges whilst in the ignition switch, mine came with 2 keys & I alternate the use of them to keep them charged.
Post #589842 Mon Nov 04 2019 3:40pm
Stu
United Kingdom 2010 Range Rover Sport TDV8 HSE Nara Bronze
i was under the same impression, that the keys charged up during use! i have had many Green Oval vehicles over the years and never changed a battery in any of them! Current: 2010 RRS 3.6 TDV8 HSE
Past: 2012 4.4 TDV8 Vogue
2007 3.6 TDV8 Vogue
2005 3.0 TD6 Vogue
2007 D3 Commercial
2001 D2 4.0 V8 ES
1998 D1 3.9 V8 ES
1988 3.5 V8 EFI Vogue
Others: 2007 VW Touareg 3.0 V6
1998 Jeep Grand Cherokee 4.0
1990 Mitsubishi Shogun 2.6
Post #589867 Tue Nov 05 2019 6:23am
The later ones do have a changeable battery in them as they're keyless in use, but a 2007 has a self-charging key. 2012 SDV6 - it's missing a couple of cylinders
Post #589875 Tue Nov 05 2019 9:36am
Stu
I’ll have to sell the RRS before the battery runs out then! Don’t like tackling complex jobs!.. Current: 2010 RRS 3.6 TDV8 HSE
2007 3.6 TDV8 Vogue
2005 3.0 TD6 Vogue
2007 D3 Commercial
2001 D2 4.0 V8 ES
1998 D1 3.9 V8 ES
Post #589884 Tue Nov 05 2019 11:14am
aaronjb
One of my fobs needs the battery replacing.. last time I pulled the side off all the bits (emergency key, a little metal springy bit) flew out and I spent 10 minutes trying to get it back together Whistle Mr. Green I haven't been brave enough to try and find the battery, yet! Embarassed 2014 BMW 530d Touring, 2006 BMW 650i, 2018 Mini Cooper S
Post #589885 Tue Nov 05 2019 11:35am
