![]() | Home > Technical > Too Many Beeps ! |
MDP Member Since: 15 Jun 2005 Location: Back in an AUDI Posts: 8598 ![]() ![]() |
A good night sleep for you then bobby |
Yes, I hope so too.
Brian Mason Member Since: 31 Aug 2006 Location: Lurking with intent!!! Posts: 5326 ![]() ![]() ![]() |
The bongs are certainly irritating, but is there a way of stopping the annoying "follow me home" lights-on feature when exiting at night, other than popping the key back in briefly? If I get out of the car amongst pedestrians, Im always told "left your lights on mate!" |
I think there is a feature in the Configurable Features called Headlamp Off Delay. You may need to turn this feature off using the Settings option. Malaysia Boleh!
Thanks Bobby. I did initially scroll though the settings options and only recall the number of seconds delay being available, NOT full cancellation of feature. I'll sit at the dashboard again and scratch my head for a bit longer then?? I'll let you know how it goes. |
Brian, would you by any chance be turning the headlamp master switch all the way to position 4? This also activates the headlamp delay mechanism. Try not turning it to position 4.. .
Hi Bobby. Yes, the headlamps are in postion 4 (auto) at all times. Does that mean I cannot cancel the "follow me home" feature at all in this position then, or can I cancel it then restore back to position. Oh dear, all very confusing. Should've stuck with my Reliant Robin!!! Thanks, Brian |
If its in position 4 then its automatic. You should try to switch on our headlights manually then. Go up to position 3 only and then see what happens when you switch them off. Hope this will work. Malaysia Boleh! 4.2SC Chawton White, Stormers Tasmod's Sills, Wind Deflectors, LR Sills Clear Side Repeaters, Towbar Larini Sports Exhaust, K&N Air Filter ______________________________ WINNER - 2008 'Tech-Head Of The Year' Award WINNER - 2009 Outstanding Contribution WINNER - 2009 'Tech-Head Of The Year' Award |
Thanks, but if there's no other way of removing the feature, I'll live with it and leave the headlights in automatic mode (4). Im a lazy sod! |
RRUK Member Since: 10 Jun 2005 Location: Leicestershire Posts: 2589 ![]() ![]() ![]() |
This car is full of features that at first we all sem to have issue with, such as the wiper stalk being the wrong side/plane of movement.
