![]() | Home > General > Gardening |
| aaronjb Member Since: 26 Jun 2019 Location: Northampton Posts: 447
No idea on the suspension .. but I feel like I need to go find the video of someone doing that with a pickup in the US (with no sense of mechanical sympathy) - the stump comes flying out and straight through the back window of the truck |
| RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9159
You were likely sat with all four wheels spinning and no forward movement at some point. There is a set of conditions that if met cause this response. The systems will have thought you were bottomed out and so raised the suspension to give you clearance. I've seen it off road once or twice.
| Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5145
some modes will automatically change the height for you I believe. |
| Stu Member Since: 23 Jun 2019 Location: North Yorkshire Posts: 123
I'm pleased that i am special for seeing extended mode without having a fault.. |
| All times are GMT |
