Home > Faults & Fixes > Front passenger door wont lock
knwatkins
It is a bit tricky. Take a look at this video on YouTube and skip to 3:35
 Kev
Post #589680 Sat Nov 02 2019 2:22pm
kenpassey
United Kingdom 2007 Range Rover Sport Supercharged HSE Java Black
Thanks for the video.. it will be useful once I get beyond the window problem.. I need to remove the glass from the nylon clamps.. this is my problem.. cheers
Post #589685 Sat Nov 02 2019 3:18pm
knwatkins
Thats exactly what they do around 3:35 - remove the glass from the clip. Kev
Post #589689 Sat Nov 02 2019 4:09pm
kenpassey
Sorry.. i overlooked it.. thanks.. thay does gove me an insight cheers. May need another helping hand to pull the glass.
Post #589692 Sat Nov 02 2019 4:37pm
knwatkins
Yes, an extra set of hands to pull the glass upwards will be an advantage. I found it difficult the first time I did it.
Also have a look here... https://www.disco4.com/forum/replacing-doo...33743.html Kev
Post #589693 Sat Nov 02 2019 4:41pm
kenpassey
Thank you Very Happy for your help, i am a lot wiser after your assistance.. Ill give it a go on Monday.. weather permitting. cheers and Thanks.
Post #589710 Sat Nov 02 2019 7:21pm
Farmer Chalk
When you actually see how it works you can’t believe it’s so simple...
The white plastic clip is simply a spring loaded clip... the button which clips into the hole in the window pane needs to be released from the door skin side not the door card side...
The way I did it was put the window half way up... then remove the rubber trim from the bottom of the window... this just prises up and out... don’t know what it’s like on the RRS but on the Discovery there are tiny nuts which need releasing at the front end of that strip.. the nut can be found when you open the door and it can be seen on the front leading edge...
Once you’ve removed that strip you can see down inside the door and you can see the white plastic clip holding the window in place.. I slid a long white ruler or a sliver of plastic down between the glass and the clip which opens up and releases the button holding the glass...
I taped the glass in place and then just powered the window down again which released the window from the lever arm...
When you see how simple it is you’ll kick yourself! Fear not I was in exactly the same position as you trying to release it from the door card side and couldn’t fathom it out... hands were cut to pieces!
Good luck.... little advice when you are taking it apart take lots of photos on your phone especially the door lock cable fitment and cable /door handle to show it it fits back!
Post #589719 Sat Nov 02 2019 9:53pm
kenpassey
Thank you for the advice, that sounds an easier method, if indeed the range rover sport window is the same, I'll have a look in the morning. Again I must thank you Farmer for your help and time. Cheers 😊
Post #589721 Sat Nov 02 2019 10:23pm
I actualy managed to do a Sport o/s rear one without removing the glass from the motor, just undid the motor assy. dropped it all down and pushed to one side. Not sure if you can do same with front though.
Post #589732 Sun Nov 03 2019 1:29am
kenpassey
Thanks Col.. good to know cheers.
Post #589758 Sun Nov 03 2019 12:04pm
