Home > Faults & Fixes > Tdv8 2007 cant build touque in 2nd gear
Terryok
As above in second gear car will build touque if feathering the throttle but flooring it in second at low revs gearbox jerks and either changes up too soon or displays F read codes got the normal incorrect gear ratio codes strange because apart from this gearbox behaves as it should any help appreciated
Post #589463 Tue Oct 29 2019 8:27pm
OvalAutos
You could start with checking the fluid level. The engine needs to be running when you do it. Joe
Post #589495 Wed Oct 30 2019 3:10pm
Terryok
Thank you will check
Post #593974 Wed Jan 29 2020 10:44am
