Home > Maintenance & Modifications > 2009 RRS SC 4.2L Oil Light Issue |
What Truck do you have.? I’m a Scania trained mechanic Andy.
Thu Oct 17 2019 8:23pm |
rayodunne Member Since: 17 May 2018 Location: Sudbury Posts: 33 |
2009 Range Rover Sport 4.2L Supercharged, Jaguar Engine |
Thu Oct 17 2019 8:51pm |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4797 |
At least 2 other occourances on diesels. |
Thu Oct 17 2019 8:54pm |
I found a thread on the LR3 having an oil light issue with water ingress on the A-Pillar. Apparently the water lands on the fuse box behind the glovebox and causes the light. There was a TSB.
Thu Oct 17 2019 9:02pm |
So today the oil light came on but this time I had my fog lights on and the fog light symbol on the dash went out when the oil light came on. Neither rear or front fog light symbols on the dash work when the oil light is on. When the oil light comes on I also get whatever messages I got on startup like "low washer fluid"
Wed Oct 23 2019 1:05pm |
Codes from Instrument Panel
Wed Oct 23 2019 1:06pm |
Came across this image today. Added to my list for the weekend.
Wed Oct 23 2019 3:53pm |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 8847 |
2012 SDV6 - it's missing a couple of cylinders 2008 TDV8 - it was a labour of love and is much missed |
Wed Oct 23 2019 5:53pm |
Mine has a plastic cap seal thingy which I assume is to stop water ingress. 2012 5.0 SC AB Mods: TPMS Genuine LR DRLs Remote Boot close from key fob 2016 Discovery 4 Mirrors AKA RRS2 2014 L405 Surround Camera retro fit (WIP) 2013 RRS Dual View Screen fit (Complete) 2016 LR4 RSE 2014 LR4 Homelink 2016 FFRR Electrochromatic Wing Mirror Glass 70 plate Focus ST (Current) 1942 VEP Ford GPW Jeep (Willys) (Current) 1943 Whites M16 Halftrack (Current) 16 plate Eurofighter Typhoon, 2 x Eurojet engines with 20,000lbs thrust each. 1380mph |
Wed Oct 23 2019 6:49pm |
aaronjb Member Since: 26 Jun 2019 Location: Northampton Posts: 447 |
"Chassis tit" .. That's what I'm going to call every ground stud, from now on.
Thu Oct 24 2019 8:25am |
I tried to locate this stud on the weekend and could not find it. Where exactly is it? 2009 Range Rover Sport Supercharged |
Mon Oct 28 2019 4:27pm |
PaulA Member Since: 23 Mar 2021 Location: CA Posts: 3 |
Was this issue ever resolved? I have an 08 RRS oil light on, fogs don't come on, windshield fluid low warning on start--exact same prob as reported here. Was it the chassis tit/grounding or instrument panel? Am told it's the instrument panel and replacing will be $1500. Thanks all! |
Tue Mar 23 2021 8:37pm |
Low washer. |
Tue Mar 23 2021 8:40pm |
This oil light. |
Tue Mar 23 2021 8:41pm |
