Home > Faults & Fixes > White smoke on start-up
Guyzer73
Oman 2006 Range Rover Sport Supercharged Vesuvius Orange
As the title says, I'm getting white smoke on start-up from my 2006 4.2SC, it stops after a few seconds of idling. It's basically a good puff of white/ light grey smoke with a acrid (not sweet like coolant burn) smell.
I checked here and there's nothing that matches my symptoms...
There's no loss in power, no fault codes via the IID Tool and coolant level seems stable.
It's most obvious when I leave the car standing for more than a few hours.
Weather here is warm (28C plus) and humidity has been high if that makes a difference.
Is it something to worry about or is it just condensation in the pipes burning off, which I don't believe as then there shouldn't be any real odour to the exhaust fumes.
Any tips and advice would be great thanks.
Guy 2006 RRS S/C CONSTANTLY under modification...
1994 RRC 4.2l not LSE sadly gone but not forgotten
LR Defender 300Tdi - affectionately know as "The Black Beast"
Post #588559 Mon Oct 14 2019 6:41am
rangemogger
Spain 2008 Range Rover Sport TDV8 SE Rimini Red
I would start with a engine compression test . TdV8 mapped and egr deleted , 265/60 r18 on Compomotive rims , Navarricos underbody protection , custom rocksliders , Devon44 hidden winch 9500i , IIDTool
Post #588651 Tue Oct 15 2019 7:18pm
Guyzer73
Open heart surgery has commenced....
Should be ready in just over a week and as good as new Very Happy
Plus they will check the gearbox shunt and transmission whine while they're at it... 2006 RRS S/C CONSTANTLY under modification...
Post #589403 Tue Oct 29 2019 5:59am
So what was the problem diagnosed as or are they still investigating?
Post #589404 Tue Oct 29 2019 6:06am
Guyzer73
Basically as suspected gasket failure and coolant in the engine.
So initially they'll strip back the engine and check everything. Hoping that it didn't make it's way to the crankshaft...
Currently, been quoted for labour, plus all parts to replace head gaskets, water pump, thermostat as well as machining heads and checking valve seating etc...
So a fairly comprehensive job for the old girl....
Post #589405 Tue Oct 29 2019 6:10am
Guyzer73
I'd say their being cautious.....
Hope they don't have anything leftover after they put this lego puzzle back together... 2006 RRS S/C CONSTANTLY under modification...
Post #589408 Tue Oct 29 2019 8:59am
knwatkins
Please keep us updated with more cool pics Guy Bow down Kev
Post #589410 Tue Oct 29 2019 9:44am
That's a comprehensive repair! Let's hope they don't have any little bits left over once they put it back together... Whistle 2012 SDV6 - it's missing a couple of cylinders
Post #589415 Tue Oct 29 2019 10:30am
Guyzer73
You and me both... Whistle
But in theory it should be as good as new when I get her back.... 2006 RRS S/C CONSTANTLY under modification...
Post #589416 Tue Oct 29 2019 10:32am
yikes! --
Post #589431 Tue Oct 29 2019 1:42pm
Scrumpy
I hope it's not all in vein!!
I have the same model as yours and I had white smoke on start up once and it was noticeable but then it never happened again!
Love your pics though 2016 RRS SVR Estoril Blue
Post #589469 Tue Oct 29 2019 11:57pm
Guyzer73
Cheers Scrumpy,
Shouldn't be in vain as the car using drinking coolant and the white smoke more noticeable all the time.
The garage has confirmed coolant entering the engine via the cylinder head gasket.
So the full strip down is to ensure the coolant hasn't reached the crank and the big bearings etc.
TBH it seems a bit excessive but I guess better to pay for it once and get it done properly then to have to take it back a few months later and pay twice... It's not exactly a cheap repair... 2006 RRS S/C CONSTANTLY under modification...
Post #589472 Wed Oct 30 2019 6:58am
aaronjb
Once you're that far into an engine, costs tend to escalate due to the "While I'm in there" factor Laughing That's how I went from a basic rebuild of a 7.0 V8 into a new 7.5L stroker rotating assembly, heads, rockers, cam, throttle bodies .. Embarassed Embarassed
Still, might as well have them throw new shells etc in - those parts are cheap insurance Thumbs Up 2014 BMW 530d Touring, 2006 BMW 650i, 2018 Mini Cooper S
Post #589477 Wed Oct 30 2019 9:13am
Guyzer73
And so it begins....
I'm heading there shortly to discuss findings and way ahead, so will see what they say... 2006 RRS S/C CONSTANTLY under modification...
Post #589483 Wed Oct 30 2019 10:53am
Guyzer73
And back together again....
Few more things in fixing along the way, but 7ltimatwly these are wear and tear parts like front control arm bushes, discs, pads etc....
Cheers 2006 RRS S/C CONSTANTLY under modification...
Post #589492 Wed Oct 30 2019 2:38pm
