Home > General > RRS cutting out in the fast lane!!
jimborani
United Kingdom 2009 Range Rover Sport TDV6 HSE Siberian Silver
Hi
A friend of mine has an 09 RRS which keeps cutting out when driving, it was a bit unnerving at first when your Big Cry out in the outside lane and you lose everything. You have to put the car in neutral (auto box) turn it off the then turn it back on and it resets. RR main dealer have had it and even though it happened while a mechanic was driving it they have still not been able to fix it. Does anybody else know of this fault? Any help would be gratefully received, we have changed the fuel pump now as they said it was low fuel pressure, we have also changed the EGR valve! Getting desperate now I was in it the other day with him and it was happening every 20 minutes or so
Probably should mention its LH drive not that that should make a difference
A bit more info on the small screen box on the RPM gauge the Suspension system light comes on and the DSC light comes on when it cuts out. also, on the main RPM gauge another red triangle with a circle around it comes on as well, not sure what one this is.
Post #528004 Mon Jun 12 2017 3:14pm
jednelson
Have had the same problem for about a year.
Bought a magic box and code pointed to MAP sensor.
Had my local indie (Paul Marley, Staxton) check and clean the sensors, all O.K. but he found a crack in the inlet manifold.
Hopefully having that replaced will sort it.
Hope this helps.
Wink
Post #528747 Thu Jun 22 2017 3:04pm
Tyrefitter
Glad you posted this Jednelson,,he's only down road from me & I didn't know he was there,,a chap just round corner from me who sells motorhomes owns the Merrylee's site.
Andy Andy.
21 Ford Ranger
Gone but not forgotten
Focus RS Red Edition
2015 RRS AB Fuji.
2014 RRS SC Santorini
2016 VW Amarok
2014 RRS AB Fuji
2012 RRS Red Edition Fuji
2015 Nissan Navara
2012 RRS SE Santorini
2008 RRS White
2007 RRS Santorino
Post #528749 Thu Jun 22 2017 3:14pm
Paddi
Crankshaft position sensor?
Main dealers are not much good at diagnosing faults like this - but they'll happily carry on changing expensive parts at your friend's expense though.
You need a good independent - hopefully someone will recommend one near to you if you ask here. 2008 MY Java Black TDV8 HSE
Post #528759 Thu Jun 22 2017 5:40pm
Hog
Netherlands 2012 Range Rover Sport SDV6 HSE Lux Buckingham Blue
i agree with Paddy. Might be crankshaft position sensor RRS 3.0 SDV6 HSE Lux
RRS 3.0 TDV6 gone
LR 3 HSE V8 gone
DiscoveryII V8 Gone
Discovery 1 V8 Gone
Mustang Shelby
Alfa Guilia (classic)
Post #528760 Thu Jun 22 2017 5:55pm
jednelson
Small world Tyrefitter, Paul's just down the road from me too!!
Highly recommended, knows his stuff.
Jed
Post #528791 Thu Jun 22 2017 9:27pm
Ian335
United Kingdom 2011 Range Rover Sport 3.0 TDV6 HSE Orkney Grey
RR Sport cutting out
My 2011 R R Sport suffering the same problem.Keeps cutting out after 5 miles or 40 miles. Local Indy fitted new LP fuel pump and battery.Still cuts out, told me to refill with good fuel and see if it is cured.Still cuts out.sometimes no warning lights, sometimes a few.I am thinking dirty Erg valves, dirty Maff sensor .Not sure where crank positioning sensor is located.Any advice would be appreciated. Thanks Ian North Wales.
Post #588539 Sun Oct 13 2019 2:57pm
knwatkins
I've heard this can be an issue if the earth strap is corroded. Kev
Post #588562 Mon Oct 14 2019 7:27am
Ian335
Thanks Kev,I will check
Post #588584 Mon Oct 14 2019 5:56pm
knwatkins
For reference.
Joe at JAS really knows his stuff...
 Kev
Post #588591 Mon Oct 14 2019 6:50pm
CornishRob
United Kingdom 2006 Range Rover Sport TDV6 HSE Sumatra Black
The as others have said, this would be the first thing to check (ie change), if it was me. It's one of the few things that can cause the engine to stop (ECU thinks it's no longer turning). Other things like EGR valves, MAP sensors can/will cause rough running, but not stop it. Thumbs Up
Post #588820 Fri Oct 18 2019 10:37am
Ian335
This has been sorted at last.It was a faulty crank sensor.Car is running well now.
Post #592287 Mon Dec 23 2019 3:52pm
knwatkins
Good to hear it's all sorted Thumbs Up Kev
Post #592290 Mon Dec 23 2019 4:50pm
