Home > Technical > Suspension not rising smoothly? |
Duc750 Member Since: 27 Mar 2019 Location: Northampton Posts: 158 |
raising it or lowering it while stationary places a hell of a train on the car o you could be seeing the tortured bushes and control arms complaining 2012 SDV6 HSE (technically its hers)
Sat Oct 12 2019 9:45pm |
Brit Plumber Member Since: 05 Jan 2018 Location: Sleaford, Lincolnshire Posts: 1847 |
As above, try changing on the move slowly. It shouldn’t be jerky but if it is, even when moving, inspect the air bags/shocks and othe suspension parts. 2012 5.0 SC AB
Sun Oct 13 2019 1:03am |
I NEVER alter my suspension while stood still,I always press the lower down button as I’m approaching my drive so by the time the car as stopped it is fully down,then when I set off I again wait till I’ve set off to raise the suspension so it’s not putting strain on the suspension components,rubbers ect. Andy.
Sun Oct 13 2019 8:46am |
Eaters Member Since: 11 Apr 2016 Location: East Sussex Posts: 1532 |
It just seems logical that it should be a smooth operation. (Mine is still smooth - after 91,000 miles albeit an older model). So that fact that it isn't does point to an issue of some sort. And of course things like this can be very expensive to fix so I'd flag it as an issue whilst you still have the chance to walk away. Robin
Sun Oct 13 2019 9:35am |
the only other thing i will add is air suspension systems sometimes do "overshoot" a little when they are aiming for a target height - I've seen this on lots of air suspension cars and nearly every truck and trailer combination when switched back from manual to self levelling mode has done this. That doesn't appear to be what you describe though. 2012 SDV6 HSE (technically its hers)
Sun Oct 13 2019 9:55am |
Pete-B Member Since: 12 Oct 2019 Location: Gloucestershire Posts: 2 |
Thank you everyone for replying, much appreciated.
Sun Oct 13 2019 5:55pm |
PC76 Member Since: 01 Oct 2017 Location: Northwest Posts: 384 |
Hi Pete,
Mon Oct 14 2019 2:32pm |
HughN Member Since: 10 Sep 2017 Location: Near Llanybydder Posts: 651 |
^^ Or a leak? |
Mon Oct 14 2019 8:17pm |
