Home > General > EPB (parking brake) seized in off position - rusted screws
PC76
United Kingdom 2010 Range Rover Sport 3.0 TDV6 HSE Adriatic Blue
Hi All,
Well i have had chance to look at the issue properly now and can confirm that it was the retaining spring in off side rear hub must not have been seated properly and allowed the cable to detach from the lever.
Had a good look at he module but the screws look to be too far gone to unscrew, certainly from underneath. (see pic)
i noticed that the rear brake lines are very corroded so i will need these replacing very soon.Also ACE pipes could do with replacing looking at the condition of the front ones....
my initial thoughts were to lift the body to allow access to the module and replace the screws with new, hence no new module required, and also replace the brake lines at the same time. i can hire a two post lift by the hour / day so i would expect to need it from Friday night through to all day Sunday to complete.
is this a sensible approach or are there other ways?
thanks in advance.
Post #588466 Fri Oct 11 2019 8:26pm
Brit Plumber
I would give those heads a clean with a brush, then squirt with penetrating oil and leave for a while and then have a go at undoing them. The moulding is plastic so the rusty screws can’t corrode into badly. 2012MY RRS 5.0 Supercharged Autobiography (Current)
Mods:
TPMS (Complete)
Genuine LR DRLs (Complete)
Remote Boot close from key fob (Complete)
2016 Discovery 4 Mirrors AKA RRS2 (Complete)
2014 L405 Surround Camera retro fit (WIP)
2013 RRS Dual View Screen fit (Complete)
2016 LR4 RSE (Complete)
2014 LR4 Homelink (Complete)
2016 FFRR Electrochromatic Wing Mirror Glass (Complete)
67 plate Focus ST Line (Current)
Post #588475 Fri Oct 11 2019 11:28pm
