Home > Technical > The annoying "Restricted Performance"
Darren Anthony
United Kingdom 2010 Range Rover Sport 3.0 TDV6 HSE Java Black
So today I was on my way to Silverstone. When suddenly while driving along the M40 I get the "Restricted Performance" warning and the red triangle.
I noticed a definite bit of air whistle while the warning was on.
After being parked up for a few hours, the warning had gone and it was driving normal with no problems, then after a while at a constant speed, it came back on again.
I'm certainly no mechanic, but I'm thinking the fact it can drive fine after being parked up would probably mean that something is sticking/jamming somewhere, otherwise it would be running on less power all the time. And the warning would be staying on.
So, any ideas what the cause may be? I've seen a few different threads on ere but it seems there are various things that can cause it. But hopefully some can already be ruled out due to it being able to run o.k. after sitting for a while.
Post #588167 Sun Oct 06 2019 6:58pm
Puslinch
United Kingdom 2012 Range Rover Sport 3.0 TDV6 HSE Firenze Red
Start with having a look for any codes that might appear. I had this happen during the summer and took 5 trips to the dealer to remedy a cross over pipe issue.
With this said, restricted performance can be due to a lot of issues. Mine did exactly the same and rarely showed a code that was the gremlin, I did towards the end have the smell of exhaust in the cabin, they found the cracks in the cross over pipe.
It's a painful journey diagnose this error. 2018 Telsa MS
2012 Range Rover Sport HSE+
1990 Porsche 944
1985 LR 90 Soft top V8
Post #588190 Mon Oct 07 2019 5:58am
Darren Anthony
Yeah. I did a search first and there seemed to be numerous different things being done by people to try to remedy the error.
Seems it is a very general message for a lot of different things.
I've just ordered a new ODB code reader which should be here tomorrow (the one I have is VAG specific, so I didn't want to try plugging that one in). So hopefully might get some kind of error code to possibly point towards the right direction.
Post #588205 Mon Oct 07 2019 12:32pm
Hog
Netherlands 2012 Range Rover Sport SDV6 HSE Lux Buckingham Blue
How much they charged you and was it a body off repair? RRS 3.0 SDV6 HSE Lux
RRS 3.0 TDV6 gone
LR 3 HSE V8 gone
DiscoveryII V8 Gone
Discovery 1 V8 Gone
Mustang Shelby
Alfa Guilia (classic)
Post #588209 Mon Oct 07 2019 12:57pm
Puslinch
Thankfully it was under warranty and replaced a melted fuel line at the same time, body on. 2018 Telsa MS
1990 Porsche 944
Post #588216 Mon Oct 07 2019 2:29pm
Darren Anthony
New reader arrived today.
Hooked it up and got:
P006A MAP Mass Or Volume Air Flow Correlation.
A quick google for P006A on a Range Rover Sport seems to point at 3 possibilities.
Faulty MAF sensor
Cracked inlet manifold
Sticking turbo solenoid valve.
Although no actual idea if it is one of those things yet.
Post #588278 Tue Oct 08 2019 4:21pm
Darren Anthony
Thinking about it, I'm guessing it's not going to be the MAF sensors, a if one of those was faulty, the warning would be on all the time.
I'd have also thought if it was a cracked inlet manifold, then that would also be affecting it all the time. So I'd suspect a sticking solenoid.
Obviously, I'm just going on looking at it logically. But we all know there is very little logic to these engines at times!
Post #588310 Wed Oct 09 2019 12:40am
Stu
United Kingdom 2010 Range Rover Sport TDV8 HSE Nara Bronze
The intake pipes are the most likely in my opinion, this was a very common fault over on the FFRR forum. My 4.4 TDV8 had two of the four inlet pipes split when i was getting the restricted performance. The manifold doesn't show all the time as when the engine is just steadily moving around town it's not under much pressure. As soon as you get on the main roads and load it up it starts sucking and opening up the splits.
Goos luck, let us know how you get on.. Thumbs Up Current: 2010 RRS 3.6 TDV8 HSE
Past: 2012 4.4 TDV8 Vogue
2007 3.6 TDV8 Vogue
2005 3.0 TD6 Vogue
2007 D3 Commercial
2001 D2 4.0 V8 ES
1998 D1 3.9 V8 ES
1988 3.5 V8 EFI Vogue
Others: 2007 VW Touareg 3.0 V6
1998 Jeep Grand Cherokee 4.0
1990 Mitsubishi Shogun 2.6
Post #588313 Wed Oct 09 2019 6:26am
Darren Anthony
After driving it today, this actually sounds very likely.
When accelerating I get a definite sound of air, which I’m pretty sure wasn’t there before.
Post #588326 Wed Oct 09 2019 1:26pm
Darren Anthony
Slightly late follow up to this.
But it turned out to be the offside inlet manifold.
Had a pretty big split. Found with a compressed air test, as it couldn’t be seen visually.
So all has been good for a while now (probably just jinxed it now lol) 2010 RRS 3.0 TDV6 HSE
1992 Mazda RX7 FD3S
Post #594452 Thu Feb 06 2020 5:32pm
Lindab
Its good to see you posting up the final fix. So many times people ask for help and get various replies but never come back to say how the problem was solved.
Post #594457 Thu Feb 06 2020 7:48pm
Stu
Ditto above!! Glad to hear you are all sorted.. Thumbs Up Current: 2010 RRS 3.6 TDV8 HSE
2007 3.6 TDV8 Vogue
2005 3.0 TD6 Vogue
2007 D3 Commercial
2001 D2 4.0 V8 ES
1998 D1 3.9 V8 ES
Post #594679 Tue Feb 11 2020 7:28am
bmszabo
Netherlands 2013 Range Rover Sport 3.0 TDV6 Autobiography Orkney Grey
Had exactly the same - but with my LR Discovery. Pretty expansive reparation.
Post #594698 Tue Feb 11 2020 1:21pm
