Home > Technical > NO TV |
maci234 Member Since: 12 Oct 2014 Location: scotland Posts: 165 |
HAS ANYONE RETROFITTED TV IN THERE L494 RRS AUTOBIOGRAPHY DYNAMIC 2013/14 |
Mon Oct 07 2019 1:56pm |
maybe most wiring is there required if required alot of things can be plug and play without coding need some experts |
Mon Oct 07 2019 5:10pm |
Unless LR have changed the way they market their products, the L494 won’t have any wiring for the TV. They haven’t provided the wiring in any model thus far that hasnt had it installed at the factory. The MOST definitely won’t be there as it requires a loop to bypass the module if not installed and LR wouldnt want the added expense or want the trouble of an extra risk of a fibre optic being damaged.
Mon Oct 07 2019 8:49pm |
do you know of anyone that may have done it ,maybe aftermarket options , |
Mon Oct 07 2019 10:38pm |
I don’t know of anyone who’s done it, probably due to it being crap! I have it in mine as factory fitted and it’s only any good when parked for a few minutes. On the move it loses signal and if parked with the engine off it shuts down in 5 minutes. Aftermarket probably isn’t much better. 2012 5.0 SC AB
Mon Oct 07 2019 10:54pm |
do you know what parts i would need quiet a few things as yourself has done a few things |
Tue Feb 25 2020 4:20pm |
