![]() | Home > Technical > Watching television when parked. |
DrRob Member Since: 23 Feb 2011 Location: Hampshire Posts: 2018 ![]() ![]() |
It will drain battery if you don’t run car. * Current. 2024 D350 Defender 90. Too many modern gimmicks on it !
Ianmg12 Member Since: 06 Oct 2019 Location: Manchester Posts: 2 ![]() ![]() ![]() |
Thanks for your responses, just to clarify, if I'm parked with the engine running,I can watch no problems but if I turn the engine off the telly goes off as well, like was mentioned you would think you had 10mins or so to keep watching, I haven't checked the settings so maybe this is the problem. |
Bill Portland Member Since: 01 Feb 2017 Location: Dorsetshire Posts: 395 ![]() ![]() ![]() |
i think it depends on the state of charge of your battery too.
