Home > My Range Rover Sport > Hi from a new owner
Joeym_rrs
United Kingdom 2013 Range Rover Sport SDV6 Autobiography Santorini Black
Hi from a new owner
Hi everyone new here. Just bought my first RRS. A 2013 Autobiography. Its done 79k. Anything i should think about getting done etc. I know the belts will be due soon and maybe gearbox fluid?
Post #588039 Fri Oct 04 2019 8:51pm
Tyrefitter
Hi & welcome,is yours a RRS1 or RRS2 as 2013 was the changer. Andy.
21 Ford Ranger
Gone but not forgotten
Focus RS Red Edition
2015 RRS AB Fuji.
2014 RRS SC Santorini
2016 VW Amarok
2014 RRS AB Fuji
2012 RRS Red Edition Fuji
2015 Nissan Navara
2012 RRS SE Santorini
2008 RRS White
2007 RRS Santorino
Post #588048 Sat Oct 05 2019 7:28am
Joeym_rrs
Sorry its a RRS1 last of the old ones
Post #588055 Sat Oct 05 2019 8:08am
What's in the fridge?
United Kingdom 2008 Range Rover Sport TDV8 HSE Buckingham Blue
Good choice Thumbs Up Welcome and you're in the right place for help, the natives are very friendly 2008 TDV8 Buckingham Blue- SOLD
Post #588057 Sat Oct 05 2019 8:23am
david007
United Kingdom 2011 Range Rover Sport SDV6 SE Vesuvius Orange
Welcome and congratulations on the purchase. One thing I would do is if its still got the original locking wheel nuts fitted remove and replace them, they can fail and when they do it can become problematic trying get them off.
Post #588058 Sat Oct 05 2019 8:23am
Brit Plumber
Is it the 3.0 SDV6? 2019 5.0 SC SVA (Current)
23 plate Focus ST (Current)
Post #588060 Sat Oct 05 2019 8:25am
Definitely worth getting the gearbox flushed now. Belts due at next service I would guess.
Oh, and welcome. Thumbs Up 2012 SDV6 - it's missing a couple of cylinders
Post #588062 Sat Oct 05 2019 8:28am
Tyrefitter
Brit Plumber wrote:
Is it the 3.0 SDV6?
It will be if it’s a my13,they didn’t do the V8 after 2010. Andy.
21 Ford Ranger
2015 RRS AB Fuji.
2016 VW Amarok
2014 RRS AB Fuji
2015 Nissan Navara
2008 RRS White
2007 RRS Santorino
Post #588087 Sat Oct 05 2019 1:58pm
SRE
Spain
Front end looks low Question
I'd check the ride heights In Spain - 2018 F Pace - Frightened away from the Sports due to crank failures
Post #588094 Sat Oct 05 2019 3:35pm
SRE
Spain
Simple check for ride height with a tape measure
Centre of wheel hub to the wheel arch, Heights should be circa 460 mm In Spain - 2018 F Pace - Frightened away from the Sports due to crank failures
Post #588096 Sat Oct 05 2019 3:42pm
Joeym_rrs
I's check the ride heights
Ill have a look at the measurements given in another comment but its in access mode here. Goes up to normal height fine but ill check
Post #588123 Sat Oct 05 2019 6:19pm
Joeym_rrs
Cool ill look into it in the next couple of months. It seems smooth enough but I have read its worth getting done for peace of mind
Post #588124 Sat Oct 05 2019 6:28pm
SRE
Spain
Think about fitting a new oil pump when the belts and pulleys are bring changed. In Spain - 2018 F Pace - Frightened away from the Sports due to crank failures
Post #588138 Sun Oct 06 2019 8:23am
Joeym_rrs
Just measured...in access height its around 410-420mm. In normal its 460mm and off road height 500-510
Post #588144 Sun Oct 06 2019 10:51am
Not far out for normal ride height.
Post #588145 Sun Oct 06 2019 11:00am
