Home > Technical > Gearbox Fault Message
Stu
United Kingdom 2010 Range Rover Sport TDV8 HSE Nara Bronze
Hi guys, Not really used the RRS for a while as been moving house and generally sorting stuff out. Used it a couple of times for short journeys and as expected threw a few fault lights and messages up, but i just put these down to battery lowish. Pressed OK to reset and everything ok, nothing reoccurred.
Have driven to work this morning approx 35 miles and just as i approached work the dash lit up like Blackpool. I can't remember everything but here goes...
Gearbox fault, stability control not available drive carefully, special programmes off, forward assist not available and as i said maybe one or two others.
Is this battery again as i had lights, heater etc on this morning or is is something other. Will get codes read when i can, but what's the general opinion? i will see what happens on the way home this afternoon.
Thanks in advance for any helps and tips... Thumbs Up Current: 2010 RRS 3.6 TDV8 HSE
Past: 2012 4.4 TDV8 Vogue
2007 3.6 TDV8 Vogue
2005 3.0 TD6 Vogue
2007 D3 Commercial
2001 D2 4.0 V8 ES
1998 D1 3.9 V8 ES
1988 3.5 V8 EFI Vogue
Others: 2007 VW Touareg 3.0 V6
1998 Jeep Grand Cherokee 4.0
1990 Mitsubishi Shogun 2.6
Post #587996 Fri Oct 04 2019 6:25am
wilf
Battery would be my first suspect. MY2016 HSE D SDV6 - gone due to fuel dilution problems.
By the age of 50 you have the face you deserve - George Orwell.
Post #587997 Fri Oct 04 2019 6:52am
Stu
Just driven home from work, all still there when I started up. Got home so it’s had a 70 mile run and still Blackpool illuminations. I went back out shortly after to see a mate and boom everything reset! Stopped and started a couple of times since and not a flicker. I love these cars.. Laughing Current: 2010 RRS 3.6 TDV8 HSE
2007 3.6 TDV8 Vogue
2005 3.0 TD6 Vogue
2007 D3 Commercial
2001 D2 4.0 V8 ES
1998 D1 3.9 V8 ES
Post #588024 Fri Oct 04 2019 3:18pm
