![]() | Home > In Car Electronics > Thinkware Dashcam F770 Very Slow to 'Lock-on' to GPS Signal? |
Evo5man Member Since: 04 Jun 2017 Location: Skegness, Lincolnshire Posts: 222 ![]() ![]() ![]() |
Does anyone have a Thinkware F770 fitted in their RRS that is slow to 'lock-on' to a GPS signal?
BJH1959 Member Since: 25 Mar 2017 Location: Paredes de Coura, Portugal Posts: 410 ![]() ![]() ![]() |
I've had a Road Angel HD cam for a few years. It's always been very slow to find a GPS signal. I've been on several journeys where it hasn't picked up a signal at all.
Hi Andy, thanks for the reply. Seems that it is not just me then. I agree that it could be the windscreen, perhaps the heating wires are distorting the GPS signal? But if that was the problem, I would expect the 770 to report a low GPS signal strength when checked using the mobile app. Once my 770 has locked on to the GPS signal and the green light stops flashing it always reports a strong signal? I have contacted Thinkware Technical Dept and I am awaiting a reply. I will post the reply on here to inform others ![]() Steve |
jimbg Member Since: 29 Jan 2013 Location: No longer by the River Dart.... Posts: 1902 ![]() ![]() |
But the mobile app is not attached to the screen? |
The mobile app connects via WiFi to the Dashcam, you can then use the mobile app to change settings, view recordings and check the GPS signal strength received by the Dashcam |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5091 ![]() ![]() ![]() |
My 770's exactly the same in this part of the world, sometimes locks on straight away, other times up to 10 mins. Has been like it all the time from new (3-4 years) even in UK. Might try it with sunroof open to see if that makes any difference on mine just out of curiosity.
Three-Six Charlie Member Since: 21 Mar 2019 Location: Wigan Posts: 63 ![]() ![]() |
Mine is exactly the same. Had similar problems with both Jags I owned prior to the RRS- simply down to the elements in the heated windscreen There is a very narrow path that is unaffected in a line downwards from the centre of the rearview mirror, but my Thinkware has clearly missed this! On my XFR my dashcam was sucker-mounted so could be moved easily and with that I found that just a cm out would be the difference between a GPS signal or not. 2013 L494 5.0 SC in Chile Red |
Have you thought about buying a GPS repeater?
Paulcp Member Since: 18 Apr 2013 Location: Suffolk Posts: 327 ![]() ![]() |
I believe that it is the heating elements in the windscreen that interfere with the gps signal. Mine was always the same, could take up to 10mins to connect, but since moving the F770 to the Lexus it connects within seconds. |
Exactly right, that's why you need a repeater in the car positioned away from the front screen to "rebroadcast" the GPS signal. |
Many thanks for all the replies which has confirmed that it is the heated front screen that is causing the problem, not the F770 |
If you find and install a GPS repeater that fixes the issue, do post any results as probably be quite a few people who would be interested. |
I have the twin camera Thinkware 770, connects within seconds.....no Heated Screen In Spain - 2018 F Pace - Frightened away from the Sports due to crank failures
Will definitely sort it, there is a post on the Disc05 forum about it. 2023 P440e SE Dynamic on order -cancelled 2022 HSE Dynamic P400e 2017 Discovery 3.0 HSE Silicon Silver Nimbus interior and a few extra toys SOLD 2013 HSE Black, Orkney Grey, Ebony Seats and Ivory Interior SOLD 2006 HSE Plus a few other cars inbetween! |
