Home > General > 2008 TDV8 BOTH TURBOS GÒNE RUN WITH 60 LITRES PETROL ALLEGE |
Tobias75 Member Since: 30 Jul 2019 Location: Maidstone Posts: 16 |
@discomikey it was indeed a copart purchase, do you know the jeep ? |
Wed Sep 25 2019 10:07pm |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4338 |
Very possibly. Copart picked up one from a customer of mine. LH turbo seized, sucked oil into the engine and hydraulic locked the engine while running, suspect there is a bent rod or 2...
Wed Sep 25 2019 10:39pm |
There was fuel a flat battery dont kow what a BT unit is and the stereo works ok maps ect.
Wed Sep 25 2019 11:00pm |
rover75 Member Since: 14 Mar 2019 Location: On my way Posts: 109 |
Why do you bother when not knowing basics? unlikely to be fixable from your laptop
Wed Sep 25 2019 11:13pm |
Thanks for that I think🤔
Wed Sep 25 2019 11:26pm |
It wasn't meant in a bad way, but now you've mentioned another word than jeep.
Wed Sep 25 2019 11:43pm |
Thanks rover75, appreciated. No offence by jeep reference btw, all 4x4 are jeeps in my eyes. |
Thu Sep 26 2019 12:26pm |
😱 no, no, no, not all are jeeps....
Fri Sep 27 2019 9:43am |
Lindab Member Since: 20 Nov 2017 Location: Dundee Posts: 869 |
Ridiculous, only 77 years old & on its second engine already |
Fri Sep 27 2019 12:28pm |
SteveNorman Member Since: 18 Sep 2008 Location: somerset Posts: 7 |
The quickest way to check relative compression is find someone with a picoscope you can borrow or ideally get them to come out to the car.
Sat Sep 28 2019 3:59pm |
Today I went to perform a spill test on injectors 1-4 and the leak of pipes spurred out diesel just by turning the ignition on.
Sat Sep 28 2019 9:25pm |
Cheapest option will likely be far from best option... |
Sat Sep 28 2019 10:12pm |
So where would you get 2 new turbos from? |
Sat Sep 28 2019 10:41pm |
Brand new OEM turbos is all we fit |
Sun Sep 29 2019 10:30am |
