Home > In Car Electronics > Tracker draining battery
LG8340
England 2013 Range Rover Sport SDV6 HSE Lux Santorini Black
Had a Protector Pro Global tracker installed 2 weeks ago. On returning today after 10 days holiday my battery is drained to the point it won’t turn the engine over sufficient to start.
I am 99% certain the tracker is to blame.
Has anyone had a similar experience and is there any remedy, assuming the tracker is to lame, short of disabling it?
Any help will be much appreciated before I call the installers to complain. RRS (MY13) Santorini Black SDV6 HSE luxuary
Gone: Evoque, Freelander 2, Mercedes 320 CLK, Porsche 911's
Post #587233 Fri Sep 20 2019 12:12am
Brit Plumber
Get the installer to recheck it, a simple test should be able to confirm it. 2019 5.0 SC SVA (Current)
23 plate Focus ST (Current)
Post #587237 Fri Sep 20 2019 6:28am
trackers do that.
maybe get a big solar panel when you intend to leave the car for a long time ?
Post #587261 Fri Sep 20 2019 4:25pm
LG8340
Yes I now understand that trackers continually demand power albeit not much.
My solution was to purchase a 100AH Varta battery as the car was still on its factory fitted battery.
Happy days! RRS (MY13) Santorini Black SDV6 HSE luxuary
Post #587454 Tue Sep 24 2019 4:34pm
