Home > Maintenance & Modifications > Condensation in Headlamp Lens.
Jock 77
Scotland 2006 Range Rover Sport TDV6 HSE Java Black
Hi Lads
Noticed lately that my Headlamp has developed condensation inside the Lens, can't see any damage to the Lens. Removed the Headlamp and it has securing clips around it 2006 Sport.
Can the Lens be split from the main Body of the Headlamp, had a quick try with the clips removed but didn't appear to get any movement.
Only other option a bag of Silica hidden inside the Headlamp Body. Laughing
Cheers Thumbs Up
Post #587451 Tue Sep 24 2019 4:13pm
Stevepd
I’m sure I’ve read in the owners manual that condensation is normal. CEO has the car at the mo so can’t look.
Steve. 2006 2.7 TDV6 HSE in Cairns Blue.
Post #587452 Tue Sep 24 2019 4:19pm
Jock 77
Re Condensation in Headlamp.
Thanks Steve
I will have a look in my manual tonight . Thumbs Up
Post #587453 Tue Sep 24 2019 4:31pm
The headlights aren't sealed - indeed they have vent pipes on the back of them to allow for heating / cooling when the lights are on / off. Entirely normal to get condensation at certain times. Drive with the lights on for a bit and that will probably dry them out. Thumbs Up 2012 SDV6 - it's missing a couple of cylinders
Post #587457 Tue Sep 24 2019 4:39pm
Jock 77
Re Condensation inn Headlamp.
Thanks for the reply I will try that. Just I couldn't ever mind of having Condensation in it before ,therefore thought I had a problem.
Cheers Jock. Thumbs Up
Post #587458 Tue Sep 24 2019 4:46pm
Brit Plumber
Yes it’s in the manual and is perfectly normal. 2019 5.0 SC SVA (Current)
23 plate Focus ST (Current)
Post #587512 Wed Sep 25 2019 11:12am
Jock 77
Re Headlamp Condensation.
Thanks Again for all the replies lads.
Cheers Jock Thumbs Up
Post #587668 Fri Sep 27 2019 8:59pm
