Home > Maintenance & Modifications > TDV8 Turbo oil feed probs
richtdv8
United Kingdom 2008 Range Rover Sport TDV8 S Java Black
Quick question, should there be good oil flow to the turbo's when just turning the engine over.
I have my oil feed pipes to the turbo's disconnected on my 2008 tdv8, and want to flush out the old oil and check oil flow through the turbo oil feed pipes.
Just turning over the engine, admittedly with a weak battery is not producing ny oil at the disconnected feed pipes.
the failed turbo's (white smoke) were full of oil when I removed them so did not fail on lack of lubrication.
The oil has now been changed complete with filter.
Thanks in advance
Richard
Post #587274 Fri Sep 20 2019 8:47pm
No
Probably have to run engine for 2 seconds or more to get pressure.
Post #587286 Fri Sep 20 2019 10:26pm
