![]() | Home > My Range Rover Sport > 1 week with my RRS |
ToonArmyMick Member Since: 04 Sep 2019 Location: South Shields Posts: 7 ![]() ![]() ![]() |
Hi Everyone,
It sounds like your battery has been disconnected so you will need to reset your windows. Close them, release the window switch then pull the switch up for a couple of seconds and that will reset them to 'one touch'. Kev
Hi and welcome |
gogsy1956 Member Since: 15 Jun 2013 Location: Tyne and Wear Posts: 961 ![]() ![]() ![]() |
As has already been said,, 5 min job to reset your windows, but my drivers door mirror also appears to not fold in as far as the passenger's side,,, it's always been like that. I just assumed that was the was it was supposed to be. 2010 RRS, TDV8
They don’t do much with the engines now. Mine just had a small diameter SC pulley and a re-map which I suspect are sub contracted from OF. The OP body kit is the standard RRS dress up kit found on the Autobiography and Lux etc. The interiors usually get a makeover with a few OF marked items thrown in such as the clock, the instrument cluster and luxury matts (and I think those are Range Rover ones rebadged with OF badges). I wonder if this one came from Autolab in Blackburn? 2019 5.0 SC SVA (Current) 2012 5.0 SC AB. Sadly written off by a campervan 23 plate Focus ST (Current) 1942 VEP Ford GPW Jeep (Willys) (Current) 1943 Whites M16 Halftrack (Current) 16 plate Eurofighter Typhoon, 2 x Eurojet engines with 20,000lbs thrust each. 1380mph |
Lindab Member Since: 20 Nov 2017 Location: Dundee Posts: 933 ![]() ![]() |
Now that's what you call a garage |
aaronjb Member Since: 26 Jun 2019 Location: Northampton Posts: 447 ![]() ![]() |
I thought they were pictures taken at the supplying dealer, it's that big! |
1richard1 Member Since: 10 Sep 2019 Location: oldbury Posts: 178 ![]() ![]() ![]() |
Hi
It does look nice,I’m just in the process of putting a new unit up similar to rent out,now I’ve seen yours I might just keep it myself to put the sport in |
Starting to get garage envy |
Autobiography1969 Member Since: 17 Sep 2018 Location: S/E Posts: 479 ![]() ![]() |
I don't have one at all.
That’s not a garage that’s a Hangar! |
Assuming around Brid? I've always wondered what the rent on a unit like that would be .. not that I'm in any position to rent a unit for anything at the moment, and definitely not in your neck of the woods ![]() ![]() |
Hi Everyone,
