![]() | Home > Technical > Swarf on the diff drain plugs. |
| garrycol Member Since: 30 Nov 2010 Location: Canberra Posts: 1071
Not necessarily as long as there are no other issues such as noise and leaks - just means the oil has not been changed for a while. I would clean the magnets up, change the oil and drive for one full service and then check again 0 if there are lots of swarf maybe look further but I bet it will be OK.
| CornishRob Member Since: 19 Feb 2016 Location: Gloucester Posts: 174
OK, great. I'll keep an eye on them, and maybe change the fluid again in 12 months. Having done it once it's easy. |
If the diff oils have not been replaced before, you will have a lot of swarf from when the diffs were first installed when new and they were bedding in. I first changed mine at 80,000 and they were really dirty and as you described. The next change was a little dirty and the rest have been fine.
| All times are GMT |
