| RRSPORT.CO.UK | ||
|  | Home > General > Clarification On 2010> RRS? |
| Sit Member Since: 14 Jun 2015 Location: Bristol Posts: 211      |
 Evening,
|  Wed Sep 04 2019 7:26pm |
| Sit Member Since: 14 Jun 2015 Location: Bristol Posts: 211      | Also just read another post which has confused me a little, is it the TDV6 or SDV6 which is known for lunching its crankshaft?
|  Wed Sep 04 2019 7:53pm |
| Sit Member Since: 14 Jun 2015 Location: Bristol Posts: 211      | Ah ok that’s excellent thank you, I had in my head the TDV6 was a different beast to the SDV6 and it was one that was more prone to consuming its crankshaft than the other.
|  Wed Sep 04 2019 8:33pm |
| knwatkins Member Since: 09 Sep 2018 Location: Poole, Dorset Posts: 1139      | No problem.
|  Wed Sep 04 2019 8:43pm |
| Sit Member Since: 14 Jun 2015 Location: Bristol Posts: 211      | Again thank you kindly, that’s really helpful. I take it both belts would normally be done on a belt service then?
|  Wed Sep 04 2019 8:48pm |
| knwatkins Member Since: 09 Sep 2018 Location: Poole, Dorset Posts: 1139      | That's right. Both timing belts, plus the aux belt should be changed. However, it's not unheard of for only the front belts to be changed because the rear belt is a bit of a pain for the inexperienced.
|  Wed Sep 04 2019 8:58pm |
| Posting Rules
