Home > Technical > Disable parking sensors
Gandalf
finaly had enough after replacing all the sensors and new looms front and back and the Censored still don't work. So I,ve decided to diasable them, changed the settings in the ccf file but I still get the anoying beeeeeeeeeeeeeeep and flashing light so what am I doing wrong. If it ain't broken down it soon will
Pulling my Vanmaster tin tent with my 2005 RED RRS HSE TDV6
1973 Land Rover Series 3 110 safari Gone but not forgotten
1990 Discovery 200Tdi Gone thank god
1996 Discovery 300Tdi sadly missed
2003 Discovery TD5 Gone to LR heaven
2004 Discovery TD5 Gone to Aberdeen hope it likes it there
2005 RRS HSE Rimini Red (my Disco 3 in a posh frock) sadly selling
Think I see a pattern here
Post #586292 Tue Sep 03 2019 6:47pm
As you can edit CCF then adjust the config setting to "rear only fitted".
See if the rears then work,
If they don't. disconnect the front parking loom below the headlight.
See if the rears then work.
If you are then ready to give up, remove the 5A fuse behind glovebox!
Post #586294 Tue Sep 03 2019 6:53pm
Gandalf
tried all that was geting a general electrial failure error hence replacing the sensors and looms, will just pull the fuse a have quiet startup Very Happy If it ain't broken down it soon will
Post #586298 Tue Sep 03 2019 7:18pm
