Home > Faults & Fixes > Hazards Flashing and if RRS turned off wont start again |
shorler Member Since: 02 Sep 2019 Location: Swindon Posts: 5 |
I have had this RRS 2007 TDV8 for a few months after buying second hand. It started with battery drain issues. If you left it too long (couple of days) witout starting it would not start and the battery would need to be recharged. I had a local garage diagnose alternator problems as the voltage output was spiking. This was changed and I changed the battery myself just incase the cells were damaged from the faulty alternator. All was well for about 100 miles and then came the headache. I was driving it one day around 30 miles from home and i get a fault beep along with the doors locking and unlocking, the hazards flashing (although you cant see in the car) and the interior lught on. If I stop the car it wont start again and just comes up with vehicle lean when cornering. The fault seems to clear itself after a while and the car starts and it t will give you half a mile and come back on again.
Mon Sep 02 2019 10:51pm |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4845 |
I believe the Engine and Transfer Box are situated behind the battery, if you have cables floating around in water by the battery I would try drying all that out as can't imagine it will do the ECU's any good as water may have entered them. Only a suggestion
Tue Sep 03 2019 9:59am |
Thank you for your replies and suggestions. I will look to see what alternator was fitted but i dont think it was the densi alternator. Ive tried a few brake switches and still the same.
Fri Sep 13 2019 5:41pm |
That’ll do it, it’s probably tracked into the fuse box and other have reported the sill being very wet too. You need to fix the problem and get lots of air circulating to dry it out. 2012 5.0 SC AB
Fri Sep 13 2019 9:33pm |
Just an update - I havnt got round to fixing the sunroof drain however I sent the instrument cluster off to get repaired. It cost £200 but now the car works perfect. I have a iid tool now too and cleared the codes and nothing is coming back after driving a couple of hundred miles! |
Sat Oct 12 2019 2:24pm |
