Home > General > Front anti sway bar leak
Dream ride
Taiwan
Hello all, I’ve got a leak in my front anti sway bay where the bar comes out of the actuator. Can I use Lucas Power Steering stop leak to remedy the situation? Would like to try it before the leak gets worse or maybe by using it will maKe things worse. Is it advisable? Thanks in advance. It’s for an 06 4.2 v8. Thanks again.
Post #586265 Tue Sep 03 2019 2:30am
Brit Plumber
Not sure how that stuff works, I guess it’s sets in contact with air at the point of the leak but it may just as easily block other parts. If you intend it to be a temp fix while you save for the cost of replacement then it’s probably fine but only ever a temp fix in my opinion. 2019 5.0 SC SVA (Current)
23 plate Focus ST (Current)
Post #586269 Tue Sep 03 2019 8:15am
