| RRSPORT.CO.UK | ||
|  | Home > General > RRS Trim colour |
| Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5145      | Maybe you would like it body coloured
|  Sat Aug 31 2019 6:43pm |
| RRS Shaun Member Since: 31 Aug 2019 Location: Essex Posts: 8      | I did consider it, but think I'd prefer to keep it the same colour as it ties in with the handles and side vents.
|  Sat Aug 31 2019 6:53pm |
| Oldandconfused Member Since: 18 Jun 2017 Location: Norfolk Posts: 784      | The paint code will be on a panel under the bonnet, check your handbook for the exact location,   | ||
|  Sat Aug 31 2019 6:57pm |
| Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5145      | That’s for the body colour | ||
|  Sat Aug 31 2019 7:01pm |
| RRS Shaun Member Since: 31 Aug 2019 Location: Essex Posts: 8      | Thanks, I thought that would only give me the paint code for the body colour, not the trim pieces.
|  Sat Aug 31 2019 7:02pm |
| Red Arrow Member Since: 06 Jun 2017 Location: Scotland Posts: 595    |
 L320 with the lettering at the bottom of the tailgate   | ||||
|  Sat Aug 31 2019 7:10pm |
| RRS Shaun Member Since: 31 Aug 2019 Location: Essex Posts: 8      | Sure is   | ||
|  Sat Aug 31 2019 7:17pm |
| rover75 Member Since: 14 Mar 2019 Location: On my way Posts: 109      | IMO it might be better with a completely different colour than one there's close | ||
|  Sat Aug 31 2019 8:14pm |
| Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5156      | If it's original self coloured same as handles/vents etc. it will be Tungsten, unfortunately there is no paint code for it. If it's a 2005 car and painted it's probably Bonatti as Orkney came in with the facelift RRS1 and Stornoway Grey replace Bonatti around 2007/8 if I remember correctly. Paint code should be on front slam panel under the bonnet Bonatti is LRC659 I think, as suggested colour code to body looks so much better.
|  Sat Aug 31 2019 9:34pm |
 Doh, I misunderstood, didn't realise it was unpainted plastic we were talking about  . | ||
|  Sun Sep 01 2019 6:33am |
| RRS Shaun Member Since: 31 Aug 2019 Location: Essex Posts: 8      | Thanks for all the info, yes it does seem to be the colour of the plastic rather than paint.
|  Sun Sep 01 2019 5:17pm |
| Tim in Scotland Member Since: 30 May 2005 Location: Driving along in my automobile Posts: 17476    | For a 2005 car through to 2007 it would be Bonatti Grey for the paint colour, from 2007 through to about 2010 (facelift model) it would Stornaway as I had a 2007 Stornaway Grey TDv8 HSE 9and for those the grey plastic door handles and the vents etc were unpainted BUT the grey was an almost exact match to the plastic, Bonatti had a hint of brown in certain lighting conditions. After Stornaway came Orkney Grey fro 2010 through to L494 which in 2014 the grey became Corris Grey but at extra cost there was Causeway Grey available too. I have every sales brochure from launch to 2011 so will look to see if=f therecis a colour shade listed form the grey of the handles. The side vents are very easy to remove and paint. You have to be brave enough to use a screwdriver on the body panel to start praising them out. If you use the forum search you should find a ‘how to’ that tells you exactly how to remove them as in the early years of RRS L320 it was one of the first modifications owners did. 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
|  Sun Sep 01 2019 8:48pm |
| Posting Rules
