Home > Off Topic - Other Cars > Audi A3 Overheating - Any Ideas?
Boost
United Kingdom 2007 Range Rover Sport TDV6 SE Zermatt Silver
After some wisdom......
My Sons Audi A3 (2010) 1.6tdi is overheating, we have bled it several times (expansion bottle top of and run until warm) unless there is another way I'm missing but to no avail, It recently had a timing belt changed and at the same time we changed the water pump, but still overheating.
Yesterday we changed the thermostat but still the same, I'm fast running out of ideas, any one had the same or similar issue?
Now thinking check fan is working , but even at a steady speed with air flowing into the front it still get warm or remove rad and flush out/check water flows through it....
Any other ideas of wisdom would be apprciated.
Post #586021 Thu Aug 29 2019 6:19pm
Advanced Factors
Site Sponsor
Did you use the correct coolant? Is it G12 spec for those? Paul Redding
+44 (0)23 8052 2776
paul@advancedfactors.co.uk
Post #586067 Fri Aug 30 2019 8:16am
RRT
I have a mk1 TT with the VAG 1.8 engine, they come with a waterpump with a plastic impeller which has a habit of breaking and causing overheating. For this reason the waterpump is changed as a precaution every time I change the cambelt. MY17 RRS 4.4d V8 Autobiography - Aintree Green (also referred to on Topix as British Racing Green)
Post #586073 Fri Aug 30 2019 9:32am
Camelrock
Have you checked the rad see if it’s blocked, check for cold spots if you can, could be the head gasket or even a cracked head. You don’t say if it’s using, blowing out the coolant, if not try a new temp sensor and/or check the sensor wiring had a petrol vw polo recently where the wire had rubbed thru against the block causing the gauge to go into the read 2008 G4 RRSport TDV8 current
2009 TDCi 90 current
1994 Dakar current
Post #586846 Fri Sep 13 2019 6:26am
