![]() | Home > General (L494) > rear axle |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9086 ![]() ![]() ![]() |
The standard rear diff is an open diff, the clever one is a locking diff that also uses Torque Vectoring By Braking (TVBB). The diff can be locked for maximum traction (like the centre diff does) and also works in combination with the brakes to help on road nimbleness - by braking the inside wheel, more torque can be moved to the outer wheel which usually has more grip. 2012 SDV6 - it's missing a couple of cylinders
airwolf222helicopters Member Since: 25 Apr 2010 Location: kent Posts: 248 ![]() ![]() |
many thanks
The active diff with TVBB is what makes the Dynamic model, well, dynamic. |
naks Member Since: 15 Jul 2016 Location: Stellenbosch Posts: 1199 ![]() ![]() ![]() |
from the workshop manual:
-- 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport Supercharged V8 HSE Dynamic ![]() ![]() Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
It is also hugely effective and even on road it is interesting to see both of the diffs opening and closing even in quite benign weather conditions.
I removed the fill plug today as I thought it had no oil . due to a whine I believed to be the diff
Hi All
wilf Member Since: 08 Nov 2012 Location: on the naughty step Posts: 939 ![]() |
Because bearing noises can be so easily transmitted through the casings they sit in, I doubt you would be able to ID a particular bearing within the diff. MY2016 HSE D SDV6 - gone due to fuel dilution problems.
Hi will
mees Member Since: 17 Jul 2009 Location: bru Posts: 45 ![]() ![]() ![]() |
I have a 2015 3.0 diesel autobiografy with 40000 miles. When i drive very slowy up a steep hill. The car sounds strange, like abs is kicking in or one of the tires is slipping/rubbing. Has this something to do with the electric differential? Or is it the traction control? On flat roads the car runs fine. Is this normal? |
I don't know of that sound could be
Anyone ???
Just received car back today new differential fitted free of charge |
