Home > Maintenance & Modifications > Retro fit heated seats
CRAIGSUTTON72
United Kingdom 2008 Range Rover Sport TDV6 S Java Black
Hi.
Has anyone fitted heated seats in there S model.
Did Land Rover put the looms in on the line?
I know I will need new front seats with heater pads and also ne heater control but was just wondering if it's possible or for I just go aftermarket.
Post #585946 Wed Aug 28 2019 9:47am
I think on the original RRS the loom had every connection on it and they just used the ones required for the particular vehicle's specification. You could lift the seat bases out of one of the front seats (easy job with just 4 bolts underneath) and have a look if there are any available connections.
I'm not sure if they would also need activating in the CCF. The HVAC panel would have to be changed and you might need to tell the car that you've changed it. This is because the system disables heated seats (amongst other things) as part of the battery protection system if battery / conditions require it.
Complicated beasties, these. 2012 SDV6 - it's missing a couple of cylinders
Post #585958 Wed Aug 28 2019 11:42am
I doubt it has wiring. (well disco owners haven't).
It's 4 wires per seat. 2 for temp. sensor and 2 for element.
Andy yes you need new panel and enabling.
The factory ones are rather hot
https://www.disco3.co.uk/forum/discovery-3...78763.html
Post #585963 Wed Aug 28 2019 12:09pm
CRAIGSUTTON72
It looks like aftermarket will be the way to go.
Thanks
Post #585995 Thu Aug 29 2019 10:25am
