Home > Maintenance & Modifications > Rear Brake Caliper Piston |
gogsy1956 Member Since: 15 Jun 2013 Location: Tyne and Wear Posts: 920 |
Proper tool makes life a lot easier,, unless you have a large "G" clamp handy. 2010 RRS, TDV8
Sat Aug 24 2019 2:01pm |
The EPB works on shoes inside the drum part of the brake so no special wind back tool required. I just use a big G clamp. Have you popped the reservoir cap off to make sure you haven’t got to much fluid, especially if you’ve already sorted the fronts. 2012 5.0 SC AB
Sat Aug 24 2019 2:53pm |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4807 |
The year of your car is an important questuon |
Sat Aug 24 2019 7:15pm |
It’s a 2008 car according to his post. 2012 5.0 SC AB
Sat Aug 24 2019 7:27pm |
You shouldn’t need a wind back tool.
Sat Aug 24 2019 10:24pm |
GerryG Member Since: 07 Jul 2019 Location: Coatbridge Posts: 27 |
Got it with G Clamp, sure took some force though, other side ( pass ) is proper seixed, guy used it to tow a boat, reversing in water ) dont know whether to change the caliper or rebiild it |
Sun Aug 25 2019 1:19pm |
Thanks mate, used a G Clamp Cheers Gerry |
insiorc Member Since: 17 Jul 2016 Location: Scotland Posts: 533 |
Are these calipers non serviceable? 20+ years ago I used to remove the pads, carefully push pistons out a little further then clean corrosion to check no pitting then push back in. If the pistons were pitted then new ones could be bought. I've never worked on newer car calipers though. Edit:. Just read on another post, it's not worth repairing due to costs of complete caliper. 13MY Range Rover Sport Autobiography SDV6 - mine 14MY Range Rover Evoque Dynamic SD4 Black Pack - wife's 99MY Defender 90 TD5, Soft Top Conversion - my toy, and bairns favourite Last edited by insiorc on Sun Aug 25 2019 4:35pm. Edited 1 time in total |
Sun Aug 25 2019 2:10pm |
When I did mine last month, I popped a piece of wood in the Caliper and pushed the piston out on the foot pedal. Obviously you have to be careful how far you pump it out or else you will pop it out of the caliper and it will need refitting and the system bleeding. Once I had it out as far as I dare, I washed the the rubber boots with mild washing up liquid and covered it in tyre dressing and let that dry in. I then put rubber grease on and removed the remaining residue until it was near dry. I then pulled back the boot out of the piston groove and gave that a clean. There was some corrosion evident in the exposed areas but the booted areas were clean. I did scrape some deposits out of the piston groove and lubed with red rubber grease to help the boot seal and to protect the groove from more corrosion. 2012 5.0 SC AB
Sun Aug 25 2019 2:25pm |
Yeah it's not worth rebuilding.
Sun Aug 25 2019 5:48pm |
