Home > General > Removing front seats
Octane85
Wales
Hi guys,
I could do with removing my front seats as I'd like to remove (and replace) the existing headrest dvd screens that are installed.
How do I go about removing the seats in a MY10 ?
Post #585708 Thu Aug 22 2019 4:21pm
they are very heavy! and not easy to lift back in.
You should be able to do this job while in the car
Tilting the backrest backwards
Post #585710 Thu Aug 22 2019 5:56pm
Brit Plumber
If you can, do as stated above.
If not, you need to pop the cover off the seat belt anchor point on the seat, position the seat by moving the switches until you can get to the Torx bolt and remove it.
Now pop the covers off each foot (they can be fun).
Remove the 5 mounting Torx bolts.
Motor the seat so that the base is central over the frame and fold the seat back as far forward as it will go and motor the seat base fully up (the aim here is to make the seat as compact as possible).
Pop the front seat trim off (just 4 clips)
Now disconnect battery and leave for 10 minutes
Unscrew the seat connector block stud.
Tape a thick sheet over your door card, sill and back door and lift the seat out.
You can change some of the order but you need to move the seat back and forth for access to bolts etc. So disconnecting the battery ends up being late on. 2019 5.0 SC SVA (Current)
23 plate Focus ST (Current)
Post #585712 Thu Aug 22 2019 8:19pm
Octane85
Wales
thanks for the replies chaps... I'll try and do it with seats in the car... by the sounds of it removing the seats might be more hassle than it's worth.
Post #585713 Thu Aug 22 2019 8:25pm
