| RRSPORT.CO.UK | ||
|  | Home > General > Death Wobble?? |
| PC76 Member Since: 01 Oct 2017 Location: Northwest Posts: 402    | Do you have ACE Active Corner Enhancement? sounds like it could be leaking and no longer working... | ||
|  Thu Aug 01 2019 1:22pm |
| Davebc Member Since: 12 Jul 2015 Location: Kelowna BC Posts: 38      | Hi PC76,
|  Thu Aug 01 2019 7:41pm |
| PC76 Member Since: 01 Oct 2017 Location: Northwest Posts: 402    | Could be as simple as rear shocks have completely failed due to age.. any other symptoms? | ||
|  Thu Aug 01 2019 8:49pm |
| Davebc Member Since: 12 Jul 2015 Location: Kelowna BC Posts: 38      | Rear shocks ride fine on good pavement and seem fine off road too. Vehicle for all intents and purposes is a-ok aside from the fit it has on a rough patch of broken pavement.
|  Thu Aug 01 2019 9:53pm |
| Bardley Member Since: 26 Jul 2018 Location: Herts Posts: 150    | Dampers that are getting aged may well ride ok on normal flat surfaces. It is just the kind of surface you describe that shows their weakness and wear.
|  Fri Aug 02 2019 4:36pm |
| Davebc Member Since: 12 Jul 2015 Location: Kelowna BC Posts: 38      | Hi Bardley,
|  Sat Aug 03 2019 4:41am |
 Have ordered a full set of replacement air struts they should arrive by Tuesday and I’ll get them in ASAP and update the results. 2007 Stornaway Grey RRS HSE 4.4 V8 | ||
|  Sat Aug 17 2019 11:52pm |
| Eaters Member Since: 11 Apr 2016 Location: East Sussex Posts: 1563      |
 I had rear dampers replaced last year, and before the change the traditional bounce test ( done by opening the boot and jumping up and down on the boot floor) did manifest as excessive bouncing. Maybe my dampers were well gone but it’s an easy check to try just in case. Robin 2008 Range Rover Sport TDV8 Gone: Jaguar S-Type V8 4.2 Sport MGZTT 190 2.5 | ||
|  Sun Aug 18 2019 4:46pm |
| Davebc Member Since: 12 Jul 2015 Location: Kelowna BC Posts: 38      | Well folks, good news!
|  Wed Aug 21 2019 11:47pm |
 Anyone know how I add RESOLVED to post title? 2007 Stornaway Grey RRS HSE 4.4 V8 | ||
|  Wed Aug 21 2019 11:48pm |
| knwatkins Member Since: 09 Sep 2018 Location: Poole, Dorset Posts: 1139      | Are you doing the fronts too? I replaced mine all around and it made a massive difference to the ride. Kev
|  Thu Aug 22 2019 11:35am |
| Davebc Member Since: 12 Jul 2015 Location: Kelowna BC Posts: 38      | I do have new struts for the front to put on, wanted to try rears first and see if that resolved the issue (which it did😃) and also it started raining and I was working outside so I stopped there. 2007 Stornaway Grey RRS HSE 4.4 V8 | ||
|  Thu Aug 22 2019 8:36pm |
| Davebc Member Since: 12 Jul 2015 Location: Kelowna BC Posts: 38      | So I finally got around to replacing the front air shocks too and happy to say the Rover rides very well now.
|  Sun Sep 15 2019 10:07pm |
| Posting Rules
