![]() | Home > General (L494) > Headliner creaking |
naks Member Since: 15 Jul 2016 Location: Stellenbosch Posts: 1196 ![]() ![]() ![]() |
on my MY15, I've noticed some creaking when driving long distance/the whole day in sunny conditions.
HaggisMan Member Since: 24 Apr 2018 Location: Glasgow Posts: 139 ![]() ![]() |
Just to update on where we are with this rattle. Dealer had car for 12 days and refitted the entire headlining (involving removing the windscreen) and .... its made no difference whatsoever! The creaking is still there as bad as ever. They’ve asked me to take it back in on Friday so they can go for a run to hear it but I’m fearing they won’t have any further idea what’s wrong. Of course it’s not their fault - it’s the muppets in Coventry that can’t nail the thing together properly to begin with. No wonder they’re moving production to Slovakia or wherever it is
Tony_Boats Member Since: 28 Jan 2018 Location: Oxford Posts: 17 ![]() ![]() |
My fixed piano roof squeak solved by spraying the rubber seal with silicone spray (wd40), the rubber seal on the outside between the glass and body was causing the problem, also took to LR but they didn’t have a clue, so fixed myself |
Tony_Boats
Just to be sure, I used wd40 silicone spray, could also try gummi pflege. If you push the glass from inside (near the front frame) you might get it to squeak! |
Farmer Chalk Member Since: 02 May 2015 Location: London Posts: 546 ![]() |
I have exactly the same issue on my 2016 fixed pano roof car....the same squeak apparently coming from the overhead centre console.... complained about it and my roof headlining was removed and refitted ...the technician was brilliant and spent all day on it.... he applied lots of anti rattle tape and I thought he had cured it...
Well.....I now have an answer to my creaking headlining thanks to an outstanding technician at the dealers...put mine in for its 3year main service and mentioned the creak again... went out for a test drive and struggled to highlight the issue but it did it slightly which was enough for him...
Hi Farmer Chalk
Beadles Sidcup.....
Thanks Farmer Chalk. I’ve forwarded that info to JLR who are liaising with my dealer in Glasgow and have offered them their HQ technical specialists to help out if needed.
Good luck with it....definately keep me posted...
Just got my car back after 4 weeks (!!!) at the dealer and their body shop who removed the pano roof and headliner and re-riveted the rivets and replaced all the clips etc. And it’s not cured the problem!!!
Haggis, on my car, they replaced something to do with the sunroof for which there was a TSB out.
Naks - thanks but that may be something different as I have the fixed-pano roof, not the opening one, so it’s probably not applicable to my car. |
