Home > Technical > Restricted Performance issues MY2012
Puslinch
United Kingdom 2012 Range Rover Sport 3.0 TDV6 HSE Firenze Red
Hi gents, a few weeks back after a 200 miles run I got the dreaded Res Perf message, I scanned and no codes appeared, it reset after a shut down and restart. Went to the dealer and they said it was fixed by cleaning the air flow sensor. First drive after 30 minutes same happened and did the same all day with no codes until the last start, I got an engine warning light with code 1247, Turbocharger boost low. This one has has stayed on, the Res Perf resets after each start up.
Back to the dealer on Monday it still has warranty until December, the car has 84,000 on it other than the odd item has been dream to drive. Thankfully I didn't take it to Germany lady week!
Anyone else with this issue, I've searched and there are a few no code Res Perf threads.
Thanks. Gary. 2018 Telsa MS
2012 Range Rover Sport HSE+
1990 Porsche 944
1985 LR 90 Soft top V8
Post #584205 Sat Jul 20 2019 5:23pm
Disco_Mikey
Smoke test is required to determine any boost leaks Thumbs Up
Post #584213 Sat Jul 20 2019 7:26pm
Hog
Netherlands 2012 Range Rover Sport SDV6 HSE Lux Buckingham Blue
I got this gremlin already for a couple of years. Code 1247.00. NO Leaks (smoke test was performed by JLR dealer) no other DTC's. After turning it of for 3 minutes, the car drives strong , particularly on the highway, after turn of the ignition, Until next event, when it appears again usually after a could start. It does not seem a serious problem, but it is annoying.
As said , everything has been checked with the help of ToPiX LTB00445V3, but sofar no succes.
I now start to suspect one of the 3 vacuum solenoids, particularly the one that is controling the CSOV. Is this a on/of valve or does ot modulate?
I would appreciate your take on this Mickey. RRS 3.0 SDV6 HSE Lux
RRS 3.0 TDV6 gone
LR 3 HSE V8 gone
DiscoveryII V8 Gone
Discovery 1 V8 Gone
Mustang Shelby
Alfa Guilia (classic)
Post #584220 Sat Jul 20 2019 10:44pm
Puslinch
Back from the dealer an oring was replaced somewhere and after 160miles today pulls like a train (so far)..... 2018 Telsa MS
1990 Porsche 944
Post #584548 Sat Jul 27 2019 3:41pm
Meiang
Australia 2010 Range Rover Sport TDV8 HSE Santorini Black
I get a restricted performance warning about every week or two (sticking turbo actuators I believe) on my TDV8. When I clean the intake system it goes for a few weeks longer between warnings.
What no one can explain is the exhaust noise is so loud and defening when it happens, like some one has removed the mufflers.
Post #584627 Mon Jul 29 2019 1:59pm
Puslinch
And back to the dealer this morning. While driving a short distance yesterday I dropped it into Sport mode, a short 10 minutes later the warning light came on. This morning I did the same, started off in Sport and 10 minutes later the warning light appeared. 2018 Telsa MS
1990 Porsche 944
Post #584631 Mon Jul 29 2019 3:21pm
Stu
United Kingdom 2010 Range Rover Sport TDV8 HSE Nara Bronze
I don’t know what engine you have in your car, but on the TDV8’s both 3.6 and 4.4 the inlet manifolds split and the rubber stub pipes that join them split too. Also the inter cooler hoses can let go. All of the above can cause restricted performance errors. Current: 2010 RRS 3.6 TDV8 HSE
Past: 2012 4.4 TDV8 Vogue
2007 3.6 TDV8 Vogue
2005 3.0 TD6 Vogue
2007 D3 Commercial
2001 D2 4.0 V8 ES
1998 D1 3.9 V8 ES
1988 3.5 V8 EFI Vogue
Others: 2007 VW Touareg 3.0 V6
1998 Jeep Grand Cherokee 4.0
1990 Mitsubishi Shogun 2.6
Post #584646 Mon Jul 29 2019 8:28pm
Meiang
None of the above is a problem with my TDV8.
Post #584659 Tue Jul 30 2019 9:57am
Puslinch
It's a SDV6 3.0, all quiet from the dealer so for... 2018 Telsa MS
1990 Porsche 944
Post #584664 Tue Jul 30 2019 11:33am
Stu
Sorry can’t help any further as I have no experience of the V6 engines. Good luck anyway and I am interested to see how you get on. Current: 2010 RRS 3.6 TDV8 HSE
2007 3.6 TDV8 Vogue
2005 3.0 TD6 Vogue
2007 D3 Commercial
2001 D2 4.0 V8 ES
1998 D1 3.9 V8 ES
Post #584666 Tue Jul 30 2019 12:10pm
Puslinch
The car has been back and forth to the dealer for the same problem over the last 6 weeks. Last week I could smell exhaust in the cabin while at a stop light. Sure enough today they looked and found an exhaust leak at the rear of the engine, it's been in and out of the shop 5 times since the start! More to come. 2018 Telsa MS
1990 Porsche 944
Post #585255 Mon Aug 12 2019 3:26pm
Puslinch
Success! The cross over pipe was split along with a melted fuel pipe. The Land Rover extended warranty finally put to good use! 2018 Telsa MS
1990 Porsche 944
Post #585295 Tue Aug 13 2019 1:53pm
Brit Plumber
That cross over pipe appears to be a common failing point on the SDV6, there was a chap on the forum last year with the same issue but he was told the LR warranty wouldn’t cover it. He was battling them as in everyone’s opinion it quite rightly should be covered. 2012 5.0 SC AB
Mods:
TPMS
Genuine LR DRLs
Remote Boot close from key fob
2016 Discovery 4 Mirrors AKA RRS2
2014 L405 Surround Camera retro fit (WIP)
2013 RRS Dual View Screen fit (Complete)
2016 LR4 RSE
2014 LR4 Homelink
2016 FFRR Electrochromatic Wing Mirror Glass
70 plate Focus ST (Current)
Post #585298 Tue Aug 13 2019 3:51pm
Hog
What is not a common issue, when it comes to “ristricted performance” ?
To many issues, big or very small can cause this warning. It can be a pain in the neck . Rolling with laughter RRS 3.0 SDV6 HSE Lux
RRS 3.0 TDV6 gone
LR 3 HSE V8 gone
DiscoveryII V8 Gone
Discovery 1 V8 Gone
Mustang Shelby
Post #585299 Tue Aug 13 2019 4:22pm
Puslinch
While I'm out of the country the car has been mended and they even threw in a set of front discs. Had a bit of the steering wobble, they had been replaced last year by the dealer. 2 year warranty on the discs! 2018 Telsa MS
1990 Porsche 944
Post #585639 Tue Aug 20 2019 7:31pm
