Home > In Car Electronics > Clock spring/heated steering wheel
Fictivision
Norway 2006 Range Rover Sport TDV6 HSE Java Black
Hello, I would like to ask how to know if a clock spring has connector for the heated steering wheel?I want to upgrade my 2006 RRS but im not sure wich clock spring I should buy.I see there is lots of them on ebay for 45$ but none say that they have the connector needed for heated steering wheel.
Thanks in advance
Post #585273 Mon Aug 12 2019 10:15pm
There is only one heated steering wheel clock spring for the sport LR018556 any numbers ending 500070/80 etc. will not be heated, it needs the extra 2 pin connector in picture one. Picture 2 shows non heated. You will need the heated steering wheel and switch pack from a facelift car as well, plus a circuit board from someone like Blackbox Solutions. I think you can also get the 2 pin connector and fly lead needed from the website shop.
Post #585274 Mon Aug 12 2019 11:14pm
Fictivision
Thanks alot Col. I already got steering wheel with switch pack.
Post #585287 Tue Aug 13 2019 11:20am
Fictivision
Really expencive circuitboard from Blackbox.
Is this only solution or are there alternativer?
Amazing that this board should cost more then the steering wheel.
Post #585290 Tue Aug 13 2019 11:42am
geoffsnook
Nope they are the only ones who do them i just sold my ones second hand for a bit less than they charge rare as rocking horse Censored Thumbs Up
Post #585321 Tue Aug 13 2019 8:59pm
