![]() | Home > Maintenance & Modifications > Fitting a winch: Part 2 |
HughN Member Since: 10 Sep 2017 Location: Near Llanybydder Posts: 651 ![]() ![]() |
Part 1.
Lindab Member Since: 20 Nov 2017 Location: Dundee Posts: 932 ![]() ![]() |
Try this
∆∆∆ Ha! Excellent! |
Purchased... ![]() |
Pufftmw Member Since: 23 May 2012 Location: Carmarthenshire Posts: 1054 ![]() ![]() ![]() |
Why not a small bit of checker plate roughly number plate sized cut to fit and pop-riveted to the bumper? I would have suggested something like THESE for quick removal of the plate when needed. Might be a bit more practical than the flipper, which in a tow situation might get broken. |
Flipper looks good, remember & post a video when you have it fitted. I'm sure no one would use it when approaching cameras |
There's no 'tongue-in-cheek' emoticon to go with the 'concours' comment.
[Duplicate post] |
Good job, always nice to be self sufficient when stuck |
I picked-up some good winch-blankets from eBay - lots of velcro and pockets to add some extra mass. For about four decades we winched boats up the beach on 300 m of steel cable - only twice did it 'let go' and it was quite 'educational'. |
I knew there was another photo. First pass at grounding it. Copper a bit too thick as the nuts don't have threads to the end. Bolt needs brazing...
aaronjb Member Since: 26 Jun 2019 Location: Northampton Posts: 447 ![]() ![]() |
Check http://www.autoelectricsupplies.co.uk and https://www.12voltplanet.co.uk/ for high current capacity bus bars |
First method for gaining access to the winch is Lindab's suggestion, wired into the switch that activates the 500A isolation relay. It is allegedly IP67, but time will tell. Needs a bit of a tweak or two.
