![]() | Home > General > blistering paintwork |
Do you know the history of the car? It could be a repaired panel after damage. 2019 5.0 SC SVA (Current)
Tom_w_27 Member Since: 09 Sep 2018 Location: Norfolk Posts: 40 ![]() ![]() ![]() |
Looks like it's rusting from the inside out?? |
Rusty Novice Member Since: 04 May 2018 Location: Staffordshire Posts: 34 ![]() ![]() ![]() |
I'm afraid I don't know the history buddy Took a leap of faith earlier and REALLY pressed hard on the largest affected area as I could and relieved to say its solid underneath. Vehicle is 6yr10mth old and the manufacturers warranty for bodywork is 6years ![]() ![]() ![]() Could it be a reaction to diesel spillage from the previous owners ? |
DEVON Member Since: 15 Apr 2016 Location: Bolton Posts: 264 ![]() ![]() ![]() |
I doubt it’s diesel, but could be wrong.
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5150 ![]() ![]() ![]() |
Looks a bit like it's actualy under the paint to me, not sure what would cause it unless posibly a flaw in prep. from new.
garrycol Member Since: 30 Nov 2010 Location: Canberra Posts: 1071 ![]() ![]() |
It looks like aluminium/galvanising surface corrosion under the paint. If you were to scrape the paint away I bet there is a white powder (the equivalent of iron oxide with a steel panel) under the paint. 07MY RRS TDV6
Could the OP post a wider angle photo? Give us an idea of where on the vehicle and the direction of the marks. I’ve seen similar when body filler has been wet sanded and not had chance to dry before being painted. The filler is hdrascopic and the moisture leaches out. 2019 5.0 SC SVA (Current)
Just re-read the first post, I wonder if it could be brake fluid contamination? Not sure how it affects modern paints. 2019 5.0 SC SVA (Current)
J.Prezes Member Since: 12 Nov 2018 Location: Somewhere Posts: 9 ![]() ![]() ![]() |
Brake fluid chews through everything, including modern paints. Factory service manuals (for sure Subaru) always have something that goes like this "always wash off spilt brake fluid because it is corrosive or will damage painted surfaces or whatever". So that is a possibility. |
I know the later models are aluminium . I'm under the impression this model is steel .However I read somewhere the panels are zinc galvanised/plated first which would make them very robust indeed but I can't seem to find that link or any info regarding the L320 construction .I'm hoping yourself or anyone of the knowledgeable guys on here can provide that information The thought has crossed my mind though but I'm not brave enough to get sharp implement out yet! |
Lindab Member Since: 20 Nov 2017 Location: Dundee Posts: 933 ![]() ![]() |
Looks like brake fluid. Have you fallen out with anyone lately? |
If it was vandalism I’d expect to see it on the bonnet and doors rather than a few bits at the rear.
Mister B Member Since: 25 Apr 2014 Location: South West Posts: 179 ![]() ![]() ![]() |
Magnate ? |
