Home > Technical > 09 parking aid module |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4845 |
Not sure about YWC500312 I think it is for very early cars, but YWC500730 is a superseded part number for the other three units.
Sat Aug 03 2019 3:35pm |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4793 |
Early modules enable the fronts and slow speed
Sat Aug 03 2019 7:20pm |
Surely they all work at low speed wouldn't be much use if some only worked at 50mph.
Sat Aug 03 2019 7:30pm |
I think you missed the word enabled |
Sat Aug 03 2019 7:44pm |
There was a switch on the dash of my old 09 plate which switched the fronts on and off and the PDC automatically disabled at speeds over 10mph so not unique to early versions.
Sat Aug 03 2019 7:52pm |
But how do the front get enabled ? If you just drive forward into a space.
Sat Aug 03 2019 8:03pm |
OP, what’s the symptom before you replace your module? These cars have problems with the wiring to the sensors, it’s very unusual for a module to fail. 2012 5.0 SC AB
Sat Aug 03 2019 11:07pm |
You have to switch them on first using the PDC switch, unless you engage Reverse first then into Drive, it's the same on the facelift variant if memory serves me correctly, but could be wrong on that as can't remember last time I used the switch. Not sure what the range is but guess the fronts would keep going off in say slow moving traffic if permanently enabled Cheers Col |
Sat Aug 03 2019 11:49pm |
That’s what I thought.
Sun Aug 04 2019 9:31am |
That would drive me crazy in a traffic jam. I can see why it was ditched! 2012 5.0 SC AB
Sun Aug 04 2019 9:34am |
The only issue is when cyclists go past
Sun Aug 04 2019 7:10pm |
Scorpasmithy Member Since: 03 Aug 2019 Location: Uk Posts: 4 |
So i replaced the unit and all was fine. parking sensors working perfectly.... until this afternoon. now i have the flashing light and long beep back. any ideas? |
Fri Aug 09 2019 5:29pm |
See my post above ref. Wiring 2012 5.0 SC AB
Fri Aug 09 2019 6:19pm |
