![]() | Home > In Car Electronics > GPS memory fail |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5119 ![]() ![]() ![]() |
I think they are talking rubbish, as I don't believe there is any Backup Battery fitted to the GPS.
Markymark Member Since: 24 Jul 2019 Location: Gloucester Posts: 16 ![]() ![]() ![]() |
Maybe, maybe not. All I know is that if you put in a destination and start your journey, and happen to turn the ignition off at sometime the destination is lost. Home destination,when put in is lost if you turn off the ignition, in fact everything is lost. Turn on the ignition and it's reset back to Belgium,Grote market to be exact. |
A little more information may help, like has it just delveloped the fault, have you just bought the car and it was already like it, recently updated the map or removed the battery etc.?
scarey Member Since: 07 Jan 2011 Location: in the cloud Posts: 411 ![]() |
i'd check the cars battery...if ok try a disconnection reset.. |
The fault has only appeared a couple of months ago. One day ok,next day not ok??!?. Myself and my local Land Rover dealer have reset it back to Gloucester England, switch off and next time you switch it on, your back to Belgium,. Battery new last year,never been off since, still running original mapping software.go figure! |
Probably a GPS antennae issue. It not knowing where it is defaults. There is no backup battery in the IAM, only feed from the car battery. Have you had any work done, even if you believe it to be unrelated? Any very heavy rain? 2019 5.0 SC SVA (Current)
I don't know about the antenna, because 1 minute after I turn on the ignition, it goes from Belgium to where I am, but if I go to put in a destination, I have to change the country from Belgium to Great Britain,then all is ok till I turn it off again,then bingo it's back to Belgium again!!!When it's switched on it will find me no trouble,when programmed,no trouble,finds where I want to go and gets me there no problem. It just won't let go of Belgium!!! |
P.S. my antenna is in the side windows I have no external shark fin |
jimbg Member Since: 29 Jan 2013 Location: No longer by the River Dart.... Posts: 1909 ![]() ![]() |
It is usually the antennae that has failed.
Ok, have a read of this TSB, I think this will give you the answer.
That's rather strange as I thought all the sports had the roof antenna for the GPS. when I had a antenna issue the car never defaulted to Belgium it just didn't know where it was at any time. Cheers Col |
According to the wiring diagrams and workshop manual, both the RRS and LR4 have the GPS in the shark fin. The rear 1/4 windows have 3 antennas per side. 2 for Tv, 2 for DAB and 2 for AM/FM.
Or are we talking a 2013 reg 2014 MY L494? 2019 5.0 SC SVA (Current)
I think even the RRS2 antenna is roof mounted in the UK market, although there is some aerial/antenna fitted in the rear spoiler for something.
