![]() | Home > Technical > Air compressor |
mikewill53 Member Since: 14 Sep 2018 Location: Swansea Posts: 35 ![]() ![]() ![]() |
Could be some degrading to the rubber mounts 2019 5.0 SC SVA (Current)
gogsy1956 Member Since: 15 Jun 2013 Location: Tyne and Wear Posts: 959 ![]() ![]() ![]() |
As per previous replies,, the rubber mounts should be securely fixed at each side,,, it's the rubber itself that provides the antivibration element. If the securing bolts were loose the whole unit would tend to jump about. 2010 RRS, TDV8
That's a AMK compressor and looks to me as the rubber mounts are shot, used to be able to get a mounting repair kit which had new rubber mountings, springs, washers etc. in it. Not sure if still available as expect L/R will want to sell you a new compressor assy. for a few hundred quid. BMW and Merc use amk so might be able to get something from them. If you could see that with just taking the wheel off, then the plastic cover is missing as well, 2006 car would probably been a Hitachi comp. originally and has been replaced by the AMK and the covers are completely different so probably never fitted a new one at something like £100+ for a couple of bits of plastic.
Thanks for all the replies, much appreciated
