![]() | Home > Wheels & Tyres > tyre size probs |
I hope that is a typing error as the should be 255 not 225, standard tyre sizes I believe were 275/40 x 20" and 255/50 x 19" not sure a 255/55 was ever fitted only as a 19" durable spare, as you haven't mentioned it but I am assuming you have a RRS1.
As Col says ^ but some have fitted 275/45r20 to make it a even more comfortable ride,the 255/50r20s were fitted to the FFRR which yours could have come off.As for the cruise control it should work with any size tyre so yours could be faulty. Andy.
Yeah, I ran 275/45 x 20" for a long time. then compromised as I don't like 22's fitted a set of early SVR 21" rims with funnily enough 275/45 x 21" tyres |
Duc750 Member Since: 27 Mar 2019 Location: Northampton Posts: 158 ![]() ![]() |
Was it your local garage or specikist. I think most I've tools will tell you the information in the ECU but not all will allow you to change the CCF. ( Car config file) 2012 SDV6 HSE (technically its hers)
I played about changing the Tyre/Wheel size in the CCF files with a Gap diag. tool and it never appeared to make a blind bit of difference to any of the original default parameters, so reset it to original setting for 275/40 x 20 and left it at that.
Tubby-1 Member Since: 17 Mar 2019 Location: isle of wight Posts: 5 ![]() ![]() |
sorry yes was typo should be 255 55 20 have been on google and inputted tyre sizes and it gives me the error in speed between 255 55 20 and 175 45 20 . its a local independant garage that i have been to but he has diagnostic equipment that allow him to adjust parameters to dealer level . Am running a 07 3.6ltr v8 diesel |
175/45r20 must be a terrible ride,the original size for the TDV8 was 275/40r20’s. Andy.
Surely you mean 275 not 175. A 175 tyre wouldn't even inflate on any land rover wheel 2012 SDV6 HSE (technically its hers)
Anno43 Member Since: 12 Oct 2018 Location: None Posts: 27 ![]() |
I was on factory fitted 275/40/20. At gps of 70mph the speedo needle would be on 67mph and the digital cruise control would read 74mph.
shepp Member Since: 15 Nov 2010 Location: Bingley Posts: 441 ![]() ![]() ![]() |
It is definitely possible to change the tyre sizes on the iid tool, but I have the beta version, so it may not be available yet on the standard firmware.
Just realised I didn’t post that I went up to 275/45/20 |
rover75 Member Since: 14 Mar 2019 Location: On my way Posts: 109 ![]() ![]() ![]() |
which rim size, the 9.5 x 20"? |
These are a partial view of a print out of the actual CCF files for my own RRS1, not really sure quite sure the percentage value equates, but there are only two different wheel/ tyre size listed for the vehicle 275/40 x 20 and 255/50 x 19 which were the only factory fitted wheel/size's on a UK spec car. I fail to see how changing the CCF files to accommodate a different size wheel/tyre can actualy change anything for a size that is not even a factory option for that particular vehicle as the software etc. would not be there in the first place unless of course changing the size adds the additional software reguired. As I said I changed mine to various combinations listed in the Gap diag. and it didn't make a blind bit of difference to the speedo reading or anything else. Perhaps a e-mail to Patrick at Gap asking the question whether it actualy changes anything or not would get a definitive answer, as they are the guy's design and build that particular tool and have always found their customer service second to none. ![]() ![]() ![]() Cheers Col |
