Home > Technical > Dynamic response Lateral accelerometer C1A97-62 *SOLVED* |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 8844 |
On the 08 TDV8, the lower accelerometer is on the chassis rail near to the Dynamic Response valve block. That's below the drivers seat, by the way. Have a look under the driver's side and you should find it. 2012 SDV6 - it's missing a couple of cylinders
Fri Mar 10 2017 12:56am |
Sharpy1980 Member Since: 24 Sep 2016 Location: Kent Posts: 98 |
Fri Mar 10 2017 8:47am |
Well it seems after going round and round the houses I finally found out why I had a fault with my lateral accelerometer and why it showed a pressure sensor fault when I unplugged the lateral sensor, the plugs for the lateral sensor and the pressure transducer (no.19) in the diagram were swapped, really obvious now I found it but not before going around the houses as the live data in the IID isn't for the lower lateral sensor but for the lateral sensor within the yaw sensor which caused a little confusion but hey we got there in the end, no more warnings on the dash... for now Clickadeeclick |
Sat Apr 15 2017 8:39pm |
loquitosk8er Member Since: 16 Jul 2019 Location: salta Posts: 1 |
hi! i m trying to find the sensor that you replaced but i cant find it on the chasis. do i have to dissasambly something to reach the sensor?. will you please help me finding it? thanks!
Tue Jul 16 2019 11:08pm |
It’s just under the drivers (uk) door but looking up from under the car, it’s actually mounted to the body not the chassis it’s basically on the inner sill and there is also a valve block right near it
Wed Jul 17 2019 10:49am |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4335 |
You wont find it on a Disco3. DR/ARC was never an option |
Wed Jul 17 2019 12:29pm |
