![]() | Home > General > OBD |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5126 ![]() ![]() ![]() |
If you want cheap or value for money. you could buy one of these.
You need one that reads the whole code not just the generic code. This can then be x-ref’d to the workshop manual which I’ve found invaluable in fault finding. Saved me a lot of time fault finding on my RSE and nailed it in minutes. 2019 5.0 SC SVA (Current)
LG8340 Member Since: 27 Jul 2014 Location: London W4 Posts: 336 ![]() ![]() ![]() |
Andy thanks for the link to EBay.
The thing with ELM327 is that it’s not a device, it’s a standard. So dozens of tools use ELM327 but not all are equal. Some will clear faults but not give detailed DTCs, some will give good DTCs for the engine and nothing else. They are a bit hit and miss until you try them out. 2019 5.0 SC SVA (Current)
rover75 Member Since: 14 Mar 2019 Location: On my way Posts: 109 ![]() ![]() ![]() |
just as well buy the right tool first, gap or similar that does it all, makes it keep after first fault or two. (unless your mate has one you can borrow) |
Thanks for the advice re what OBD reader to buy.
Bruster400 Member Since: 12 Jun 2019 Location: Manchester Posts: 15 ![]() ![]() ![]() |
Hi all,
DEVON Member Since: 15 Apr 2016 Location: Bolton Posts: 264 ![]() ![]() ![]() |
P.M sent |
Just thought I'd update on my cheeky request to borrow an OBD reader.... I now have one of my own!! |
