Home > For Sale & Wanted > [Wanted] WANTED L320 05-13 dog guard loweer brackets
AW8
Hi folks,
I recently bought a used land rover dog guard for my 2005 L320 RRS but it is missing the lower bracket plates.A fitting kit costs circa £100. Part number for kit is VUB503500. If anyone happens to have a pair of the lower brackets please pm me.
Failing this a template would be great.
Thanks
AW8
[/b]
Post #582669 Wed Jun 19 2019 3:41pm
Stu
United Kingdom 2010 Range Rover Sport TDV8 HSE Nara Bronze
Just found your post, I’ve just done the same thing, bought a used one with the arms on the top, but no floor brackets.. Rolling Eyes
They seem to be like hens teeth. Current: 2010 RRS 3.6 TDV8 HSE
Past: 2012 4.4 TDV8 Vogue
2007 3.6 TDV8 Vogue
2005 3.0 TD6 Vogue
2007 D3 Commercial
2001 D2 4.0 V8 ES
1998 D1 3.9 V8 ES
1988 3.5 V8 EFI Vogue
Others: 2007 VW Touareg 3.0 V6
1998 Jeep Grand Cherokee 4.0
1990 Mitsubishi Shogun 2.6
Post #583621 Sat Jul 06 2019 1:38pm
AW8
Glad I am not alone....Hopefully my wanted advert might cause some to check their vehicles to see if they have spare floor brackets they might be prepared to part with.
In the meantime Karabiners have been utilised as a half a job make do
Post #583773 Wed Jul 10 2019 2:44pm
Stu
Laughing I haven’t even been that professional! I am using cable ties at the moment. A complete fitting kit is £100... Shocked Current: 2010 RRS 3.6 TDV8 HSE
2007 3.6 TDV8 Vogue
2005 3.0 TD6 Vogue
2007 D3 Commercial
2001 D2 4.0 V8 ES
1998 D1 3.9 V8 ES
Post #583774 Wed Jul 10 2019 3:38pm
Duc750
to be honest it stays in fine without the lower brackets 2012 SDV6 HSE (technically its hers)
2000 D2 TD5 - definitely mine
2005 D3 V8
Metalian Camper trailer for adventures
Post #583810 Thu Jul 11 2019 9:24am
Pufftmw
As Duc said, perfectly secure without any brackets.
Post #583839 Thu Jul 11 2019 8:40pm
Stu
Excuse me please if I’m being a mong!! How does it stay in place without the lower brackets? There is nothing else to support it unless I’m missing more than I thought. Current: 2010 RRS 3.6 TDV8 HSE
2007 3.6 TDV8 Vogue
2005 3.0 TD6 Vogue
2007 D3 Commercial
2001 D2 4.0 V8 ES
1998 D1 3.9 V8 ES
Post #583841 Thu Jul 11 2019 8:49pm
AW8
I have the top brackets. There are tabs that locate against the plastic either side of bootspace to stop it falling back ...it's a snug fit. Not likely to tilt baxk due to angle albeit I have used some old karabiners to restrict lower edge bottom bits popping back.
I still want the brackets ideally
Post #583845 Thu Jul 11 2019 11:18pm
Stu
Laughing I’m laughing cos I didn’t even notice them just placed it in the boot and cabled tied it in place via the head rests and load rings.. shows you observant I am. Current: 2010 RRS 3.6 TDV8 HSE
2007 3.6 TDV8 Vogue
2005 3.0 TD6 Vogue
2007 D3 Commercial
2001 D2 4.0 V8 ES
1998 D1 3.9 V8 ES
Post #583851 Fri Jul 12 2019 8:20am
Stevepd
I’ve got them fitted. Do you want me to take measurements?
189A54CE-F138-4669-BA21-1E7111F17A1F by Stephen Priestley-Dean, on Flickr
Steve. 2006 2.7 TDV6 HSE in Cairns Blue.
Post #583863 Fri Jul 12 2019 10:37am
Duc750
so its actually held in place by the tabs that go behind the seats when the seats are upright - the upper arms stop the guard top rotating forward and the frame stops it rotating backward - I think the only thing those brackets really do is stop the dog guard moving when the seats are down but the full height guard effectively stops you using the load area with the seats down anyway. 2012 SDV6 HSE (technically its hers)
2005 D3 V8
Post #583870 Fri Jul 12 2019 12:03pm
Stu
Thanks for the replies gents, I’ve just been out and had a look. It doesn’t fit properly as it’s not the right one.. Rolling with laughter
It’s the right shape to look at with the ski flap in it, but it’s not wide enough! It must be for another L/R. The number on it is: LR002521M5X7A.
I’ll have to find out which vehicle it’s for. Current: 2010 RRS 3.6 TDV8 HSE
2007 3.6 TDV8 Vogue
2005 3.0 TD6 Vogue
2007 D3 Commercial
2001 D2 4.0 V8 ES
1998 D1 3.9 V8 ES
Post #583871 Fri Jul 12 2019 12:38pm
Duc750
Freelander 2
Be aware also that there are two guards available for the L320. the late one fits both pre and post facelift but the early doesn't fit the post facelift so well.
I have an early one here without the bottom mounts if you're interested but you're a bit far away 2012 SDV6 HSE (technically its hers)
2005 D3 V8
Post #583873 Fri Jul 12 2019 1:16pm
Stu
Thanks for the offer but as you say it’s a bit far! I just checked and you are right it’s Freelander 2. I get rid in time, meanwhile I’ve got my eye on another one, this time I’ll buy the right one.. Thumbs Up Current: 2010 RRS 3.6 TDV8 HSE
2007 3.6 TDV8 Vogue
2005 3.0 TD6 Vogue
2007 D3 Commercial
2001 D2 4.0 V8 ES
1998 D1 3.9 V8 ES
Post #583881 Fri Jul 12 2019 3:31pm
AW8
Steve.
Steve,
Thanks for replying.
I would be most grateful if you could take various measurements and update me...Either on this thread or by PM.
Genuinely appreciated
Smile
Post #583899 Fri Jul 12 2019 11:48pm
