Home > General > High coolant pressure |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4798 |
often a new tank cap is suggested |
Sun Jun 16 2019 10:13am |
loonyball Member Since: 29 May 2019 Location: ballymena Posts: 30 |
still no further forward with this issue, any suggestions would be greatly appreciated before i start throwing endless folding cash at the ol' girl..... |
Sun Jun 30 2019 8:41pm |
Get the pressure measured at idle and while at 1500rpm. |
Mon Jul 01 2019 9:19pm |
No problem, if its not a stupid question, what am i looking for.
Mon Jul 01 2019 9:23pm |
rover75 Member Since: 14 Mar 2019 Location: On my way Posts: 109 |
How do you know the pressure is high and not something else?
Mon Jul 01 2019 9:38pm |
Hi rover75, thanks for taking the time to reply, pressure is high because when the car has been driven ten miles or so, the pressure builds and vents through the cap, also new tank and cap already fitted, basically, the problem is air in with the coolant returning to the expansion tank raising pressure. As stated previously twice i have run the sniff test which has proved negative, i really have hit a brick wall with this issue. |
Mon Jul 01 2019 10:04pm |
once system is bled and without airlocks, the only air possible is from exhaust in waterways.
Mon Jul 01 2019 10:30pm |
Hi, don't know you but here's the text from the workshop manual,
Mon Jul 01 2019 10:48pm |
just to follow on the issue i have with my car, i read somewhere on another forum someone had very similar symptoms as mine but it turned out to be a faulty egr cooler allowing exhaust gases get in to the coolant inside the egr cooler, i'm curious as i would have thought the pressure in the coolant system (under normal conditions) would have been higher than the exhaust pressure within the egr cooler ? maybe i am wrong, but i also got to thinking that if the exhaust gas WAS leaking into the cooling system via the egr cooler would that not show in the sniff test ?? |
Tue Jul 02 2019 8:33pm |
Yes.
Tue Jul 02 2019 9:10pm |
Harryrrs Member Since: 20 Feb 2020 Location: Luton Posts: 7 |
I am having a very similar issue and have changed
Thu Feb 20 2020 11:49pm |
No i have not found any fix for my car, it has got me totally stumped, i am convinced its not a head/gasket issue.
Fri Feb 21 2020 1:19am |
PC76 Member Since: 01 Oct 2017 Location: Northwest Posts: 387 |
Have you replaced all of the pipes?
Fri Feb 21 2020 9:24am |
That would make sense , howether it has been pressure tested how can I test this ? As coolant system is already pressurised and not leaking so surely nothing will come out of the potential vaccine pipe ... |
Fri Feb 21 2020 10:16am |
