Home > General > Wing mirrors |
Can you fold them using the mirror switch? If not, you don’t have the power fold motets so you would need new mirrors or at least the motors. 2012 5.0 SC AB
Fri Jun 28 2019 11:24pm |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4801 |
they can fold in by pressing the adjuster down (knob in center position)
Sat Jun 29 2019 10:01am |
Eskimo Member Since: 21 Oct 2018 Location: Worcestershire Posts: 72 |
I've been thinking about this too. I'm thinking that all it will need is a trigger signal on the line from the wing mirror switch which is activated when the key fob is pressed.
Sat Jun 29 2019 9:29pm |
Ptang Member Since: 11 Jan 2008 Location: Bromley, Kent Posts: 95 |
I've been toying with this idea too for my 2005 RRS.
Sun Jun 30 2019 11:05pm |
** UPDATE ** Ok, I've thought about this more after some coffee and looking back at the wiring diagrams, you can see that the "switch-mirror" signal looks like a normally-open switch that pulls C0066-8 low when activated [need to check with the trusty voltmeter]. The central locking motor line C0441-7 is a reversible polarity drive with C0441-5 to the central locking motor so my above diode idea is a non-starter.
Tue Jul 02 2019 8:13am |
Ptang,
Tue Jul 02 2019 1:16pm |
