Home > General > Tow bar electrics
Paulyh
Tow bar electrics
Hi, can anybody tell me if this is the correct part for a Range Rover sport towing electrics as mine hasn't got any fitted. I purchased this and was told would fit but just want to check first, Tia
Post #583171 Thu Jun 27 2019 8:07pm
Duc750
Well that definitely wouldn't fit on our MY12/13. 2012 SDV6 HSE (technically its hers)
2000 D2 TD5 - definitely mine
2005 D3 V8
Metalian Camper trailer for adventures
Post #583177 Thu Jun 27 2019 11:08pm
Made in 2006.
Are u sure sits for a land rover ?
Post #583178 Thu Jun 27 2019 11:25pm
Paulyh
Yes definitely Land Rover
Post #583179 Thu Jun 27 2019 11:43pm
If that is for a pre-facelift RRS1 Sport I think you will find that is just part of a kit, there should be a fuse-box that goes in the spare wheel well and a few other brackets, relay's and other bit's and pieces etc. I don't think that will simply fit to the vehicle and you have tow-bar electrics. I can't really remember fully but I think those two small spade end connectors go on the tailgate release switch as you have to remove the original harness and replace it with the new tow-bar one, but could be wrong on that.
Post #583180 Fri Jun 28 2019 12:09am
even the first part of the early kit should have 2 connectors on the end.
what year car do you have OP ?
google
eymz101120
probably for a freelander or something
Post #583193 Fri Jun 28 2019 11:48am
Stu
United Kingdom 2010 Range Rover Sport TDV8 HSE Nara Bronze
Hi guys, hope you don’t mind me butting here!
If I have 12s&n already fitted on the MY 2010 RRS, can I swap them for a 13 pin euro socket without any coding?
Any help appreciated.. Thumbs Up Current: 2010 RRS 3.6 TDV8 HSE
Past: 2012 4.4 TDV8 Vogue
2007 3.6 TDV8 Vogue
2005 3.0 TD6 Vogue
2007 D3 Commercial
2001 D2 4.0 V8 ES
1998 D1 3.9 V8 ES
1988 3.5 V8 EFI Vogue
Others: 2007 VW Touareg 3.0 V6
1998 Jeep Grand Cherokee 4.0
1990 Mitsubishi Shogun 2.6
Post #583212 Fri Jun 28 2019 6:33pm
Yea
Post #583216 Fri Jun 28 2019 7:05pm
Stu
Thanks for that Andy K, wish I’d kept my IID tool when I sold the FFRR now.. Thumbs Up Current: 2010 RRS 3.6 TDV8 HSE
2007 3.6 TDV8 Vogue
2005 3.0 TD6 Vogue
2007 D3 Commercial
2001 D2 4.0 V8 ES
1998 D1 3.9 V8 ES
Post #583219 Fri Jun 28 2019 8:35pm
Brit Plumber
Land Rover do a 12n/s to euro adapter, it’s about 8” long so doesn’t add much length to your cable. 2019 5.0 SC SVA (Current)
23 plate Focus ST (Current)
Post #583224 Fri Jun 28 2019 11:20pm
Re: Tow bar electrics
I think that lead is the 'S' plug of Kit YWJ500150 which has One multi pin connector, the 'N' plug has the Two multi pin connectors, so as I said previous I think you will find you only have part of the kit.
Post #583226 Fri Jun 28 2019 11:37pm
Stu
Brit Plumber, thanks for that, I will look into that as an option. Trailing cable is one of my issues, don’t want it dragging on the floor. Current: 2010 RRS 3.6 TDV8 HSE
2007 3.6 TDV8 Vogue
2005 3.0 TD6 Vogue
2007 D3 Commercial
2001 D2 4.0 V8 ES
1998 D1 3.9 V8 ES
Post #583229 Sat Jun 29 2019 7:56am
Col. This socket is not grey or white, so it is not the 12 S
Post #583234 Sat Jun 29 2019 10:04am
So which colour is the 'S' socket ? as L/R's kit appears to show two black sockets with one having a grey lid/flap as I was just basing it on the L/R fitting kit illustration which knowing L/R could be wrong.
Post #583236 Sat Jun 29 2019 10:51am
The one with the "a grey lid/flap" is the S socket
Post #583245 Sat Jun 29 2019 1:07pm
